haven't been posting for some time, and now i come back here with a problem we are facing since around a week. Our NagiosXI Servers Disk is filling up with performance data (in like, 2G per Minute or more). First, what i have for you:
/usr/local/nagios/var/npcd.log is filled with
[12-04-2018 10:12:19] NPCD: ERROR: Executed command exits with return code '7'
[12-04-2018 10:12:19] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1543914244.perfdata.host'
2018-12-04 10:12:19 [63357] [0] *** TIMEOUT: Please check your npcd.cfg
2018-12-04 10:12:19 [63357] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1543914275.perfdata.host-PID-63357 deleted
2018-12-04 10:12:19 [63357] [0] *** Timeout while processing Host: "al-infoweb" Service: "_HOST_"
2018-12-04 10:12:19 [63357] [0] *** process_perfdata.pl terminated on signal ALRM
2018-12-04 10:12:19 [63355] [0] *** TIMEOUT: Timeout after 120 secs. ***
2018-12-04 10:12:19 [63355] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2018-12-04 10:12:19 [63355] [0] *** TIMEOUT: Please check your npcd.cfg
2018-12-04 10:12:19 [63355] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1543914289.perfdata.host-PID-63355 deleted
2018-12-04 10:12:19 [63355] [0] *** Timeout while processing Host: "DimagTS" Service: "_HOST_"
2018-12-04 10:12:19 [63355] [0] *** process_perfdata.pl terminated on signal ALRM
&& cp /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.host /usr/local/pnp4nagios/var/spool/graphiosI'm at a total loss. I checked all permissions. Everything is run as user nagios. All permissions should be good. If you need anything else, feel free to ask. Any help here would be highly appreciated!
For completeness, i'm including the relevant configs:
npcd.cfg
# NPCD.cfg - sample configuration file for PNPs NPCD
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# it under the terms of the GNU General Public License version 2 as
# published by the Free Software Foundation;
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
# $Id: npcd.cfg-sample.in 440 2008-04-24 09:08:20Z hendrikb $
# Privilege Options
user = nagios
group = nagios
# Logging Options
# log_type - define if you want your logs to
# 'syslog' or to a 'file'
# log_type = <value>
log_type = file
#log_type = syslog
# log_file - define a path to your logfile
# needed if 'log_type'='file'
# log_file = </path/to/logpath/filename>
log_file = /usr/local/nagios/var/npcd.log
# max_logfile_size - defines the maximum filesize (bytes)
# before the logfile will rotated.
# max_logfile_size = <value> (default 10Mbyte)
max_logfile_size = 10485760
# log_level - how much should we log?
# log_level = <integer value>
# 0 = No logging - except errors
# 1 = Small logging - some few more output
# 2 = More Logging (actual ALL logs)
# -1 = DEBUG Mode - ALL Logging and slower processing
log_level = 0
# NEEDED OPTIONS
# perfdata_spool_dir - where we can find the
# performance data files
# perfdata_spool_dir = </path/to/directory/>
perfdata_spool_dir = /usr/local/nagios/var/spool/perfdata/
# Execute following command for each found file
# in 'perfdata_spool_dir'
# perfdata_file_run_cmd = </path/to/command>
# Must be executable by user/group from above
# perfdata_file_run_cmd = </path/to/filename>
perfdata_file_run_cmd = /usr/local/nagios/libexec/process_perfdata.pl
# perfdata_file_run_cmd_args (optional)
# If you wish, you can apply more arguments to the
# Hint:
# NPCD will create a command line like this:
# '<perfdata_file_runc_cmd> <perfdata_file_runc_cmd_args> <filename_from_spool_dir>'
perfdata_file_run_cmd_args = -b
# npcd_max_threads - define how many parallel threads we
# should start
npcd_max_threads = 8
# sleep_time - how many seconds should npcd wait between dirscans
# sleep_time = 15 (default)
sleep_time = 15
# EXPERIMENTAL
# use_load_threshold - enables/disables load watching
# use_load_threshold = <0 / 1> (default: 0)
#use_load_threshold = 0
# EXPERIMENTAL
# load_threshold - npcd won't start new threads
# if your system load is over this threshold
# load_threshold = <float value> (default: 10.0)
# Hint: Do not use "," as decimal delimeter
load_threshold = 20.0
# location of your pid file
#pid_file=/var/run/npcd.pid
pid_file=/usr/local/nagiosxi/var/subsys/npcd.pid
# We have to end with a newline
# Config File for process_perfdata.pl
# $Id: process_perfdata.cfg-sample.in 520 2008-09-16 12:50:10Z pitchfork $
# process_perfdata.pl Timout
TIMEOUT = 120
# Use RRDs Perl Module
USE_RRDs = 1
RRDPATH = /usr/local/nagios/share/perfdata
RRDTOOL = /bin/rrdtool
CFG_DIR = /usr/local/nagios/etc/pnp
RRD_HEARTBEAT = 8460
RRA_CFG = /usr/local/nagios/etc/pnp/rra.cfg
RRA_STEP = 60
LOG_FILE = /usr/local/nagios/var/perfdata.log
# Loglevel 0=silent 1=normal 2=debug
LOG_LEVEL = 0
# XML encoding
# The supported encodings are ISO-8859-1, UTF-8 and US-ASCII.
# http://www.php.net/xml-parser-create
XML_ENC = UTF-8
# EXPERIMENTAL rrdcached Support
# Use only with rrdtool svn revision 1511+
# RRD_DAEMON_OPTS = unix:/tmp/rrdcached.sock
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=1
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# PNP settings - bulk mode with NCPD
process_performance_data=0
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$\tLONGSERVICEOUTPUT::$LONGSERVICEOUTPUT$\tGRAPHITEPREFIX::$HOSTGROUPALIAS$\tGRAPHITEPOSTFIX::$SERVICEDESC$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$\tLONGHOSTOUTPUT::$LONGHOSTOUTPUT$\tGRAPHITEPREFIX::$_HOSTGRAPHITEPREFIX$\tGRAPHITEPOSTFIX::$_HOSTGRAPHITEPOSTFIX$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=1
auto_rescheduling_interval=30
auto_rescheduling_window=45
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=1
check_result_path=/usr/local/nagios/var/spool/checkresults
check_result_reaper_frequency=3
check_service_freshness=1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
high_host_flap_threshold=20.0
host_check_timeout=30
host_freshness_check_interval=10
interval_length=60
lock_file=/var/run/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=0
log_rotation_method=d
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=10
max_concurrent_checks=0
max_debug_file_size=1000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/usr/local/nagios/var/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
perfdata_timeout=5
precached_object_file=/usr/local/nagios/var/objects.precache
resource_file=/usr/local/nagios/etc/resource.cfg
retain_state_information=1
retention_update_interval=60
service_check_timeout=90
service_freshness_check_interval=10
service_interleave_factor=s
soft_state_dependencies=0
state_retention_file=/usr/local/nagios/var/retention.dat
status_file=/usr/local/nagios/var/status.dat
status_update_interval=10
temp_file=/usr/local/nagios/var/nagios.tmp
temp_path=/tmp
use_regexp_matching=0
use_retained_program_state=1
use_syslog=1
use_true_regexp_matching=0
# ###### Auto-generated Graphios configs #######
#process_performance_data=1
#service_perfdata_file=/var/spool/nagios/graphios/service-perfdata
#service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVICESTATETYPE$\tGRAPHITEPREFIX::$_SERVICEGRAPHITEPREFIX$\tGRAPHITEPOSTFIX::$_SERVICEGRAPHITEPOSTFIX$\tMETRICTYPE::$_SERVICEMETRICTYPE$
#service_perfdata_file_mode=a
#service_perfdata_file_processing_interval=15
#service_perfdata_file_processing_command=graphios_perf_service
#host_perfdata_file=/var/spool/nagios/graphios/host-perfdata
#host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tGRAPHITEPREFIX::$_HOSTGRAPHITEPREFIX$\tGRAPHITEPOSTFIX::$_HOSTGRAPHITEPOSTFIX$\tMETRICTYPE::$_HOSTMETRICTYPE$
#host_perfdata_file_mode=a
#host_perfdata_file_processing_interval=15
#host_perfdata_file_processing_command=graphios_perf_host
#host_perfdata_file_template=\tGRAPHITEPREFIX::$_HOSTGRAPHITEPREFIX$\tGRAPHITEPOSTFIX::$_HOSTGRAPHITEPOSTFIX$
#service_perfdata_file_template=\tGRAPHITEPREFIX::$_SERVICEGRAPHITEPREFIX$\tGRAPHITEPOSTFIX::$_SERVICEGRAPHITEPOSTFIX$
