Hi Team,
Do we have plugin that monitors the "Oracle Virtual Box" status.
To Explain : We have a Oracle Virtual box running on a Ubuntu server and inside that we have another Ubuntu box running. So we just need a plugin that tells state of the Virtual Machine, For now i would say it is enough if it tells the Running or Stopped State.
Thank You!
Plugin to check the Oracle Virtual box status
Re: Plugin to check the Oracle Virtual box status
You would likely need to install NRPE/NCPA/NSClient and run the plugin on the remote machine.
Please try the plugin listed here and let us know the results:
https://exchange.nagios.org/directory/P ... VirtualBox
