Just updated the oprations center component to 1.2.0. It seems like the filters aren't saved anymore? If I remember correctly the used filters, such as hide soft states were saved in previous versions?
Grtz
Willem
New operations center doesn't save it's filters?
Re: New operations center doesn't save it's filters?
I was able to recreate the issue and filed an internal bug report (task_id=13950). Thank you for reporting the issue! It will be fixed in the next version of the "Operations Center" component.
