Avaya switch configuration sflow collector
Avayahelp
Post by Avayahelp »
Hi ,
i have problem configuring my avaya7024XLS switch.
I have no data on my nagios network analyser....
My config :
IP Version IPv4
IP Address X.X.X.X
IP Destination Port 9418
Collector Buffer Size 1400
Collector Owner SRI
Collector Timeout 57264
i activate the interface on connector 1 but still nothing...
Re: Avaya switch configuration sflow collector
Couple of things you want to check.
Make sure the Avaya time is set and is in sync with the NNA server. So make sure the time is correct and that the time zone is set.
If the source that you created on the NNA server set to sflow? Make sure it is.
Can you post the config from the Avaya switch so we can check it?
