Having checks error after some changes
shamrozkadiwal
Post by shamrozkadiwal »
Hey All, I am getting this error when I was trying to commented out few hosts and services. Since then this error has been sitting there and not going. I tried so many thing but still not able to find where is it coming from. I was trying to commented out ddb900 and ddb901 servers from service and host and started getting this error
I have attached few configuration files if you need look into it
[shkadi@ams900 hosts]$ sudo /usr/sbin/nagios -v /etc/nagios/nagios.cfg
Nagios Core 3.5.1
Last Modified: 08-30-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config file '/etc/nagios/objects/commands.cfg'...
Processing object config file '/etc/nagios/objects/contacts.cfg'...
Processing object config file '/etc/nagios/objects/timeperiods.cfg'...
Processing object config directory '/etc/nagios/hosts'...
Processing object config file '/etc/nagios/hosts/ddx900.cfg'...
Processing object config file '/etc/nagios/hosts/eft_hosts.cfg'...
Processing object config file '/etc/nagios/hosts/ddx901.cfg'...
Processing object config file '/etc/nagios/hosts/hostgroups.cfg'...
Processing object config file '/etc/nagios/hosts/adx903.cfg'...
Processing object config directory '/etc/nagios/services'...
Processing object config file '/etc/nagios/services/eft-services.cfg'...
Processing object config file '/etc/nagios/services/servicegroups.cfg'...
Error: Could not expand hostgroups and/or hosts specified in service (config file '/etc/nagios/services/eft-services.cfg', starting on line 239)
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
hostgroups.cfg
(3.88 KiB) Downloaded 160 times
eft-services.cfg
(30.25 KiB) Downloaded 192 times
eft_hosts.cfg
(18.02 KiB) Downloaded 169 times
Re: Having checks error after some changes
In eft-services.cfg you have a service that is assigned to the D-drive_snmp hostgroup.
If commenting out these hosts, makes this hostgroup empty, you cannot assign the hostgroup to a service
shamrozkadiwal
Scott, I really appreciate your help and I resolve the issue.
cdienger
Post by cdienger »
Glad to hear!
