Hi Nagios team,
Need to setup similar/identical Dashboards across multiple NagiosXI setups.
Its pretty laborious to do this manually and especially when there are changes.
It even more to sync up across the board.
Is There a way to export NagiosXI Dashboards ?
The idea is to import on other NagiosXI web nodes , so that all Dashboards are in sync.
Kindly assist.
Regards,
Vish.
NagiosXI 5.5.9 - Is there a way to export dashboards ?
Re: NagiosXI 5.5.9 - Is there a way to export dashboards ?
Unfortunately we do not have any way to export dashboards on one system and install on another.vishfx wrote:Is There a way to export NagiosXI Dashboards ?
Locking threadvishfx wrote:ok, Thanks.
