Centos/nagiosxi migration 7
Re: Centos/nagiosxi migration 7
We always recommend a minimal install.
can i go from old server on 5.5.8 to the new which is on 5.5.10 or do both have to be on same nagiosxi version?
It would be recommended to be on the same versions.sharding wrote:can i go from old server on 5.5.8 to the new which is on 5.5.10 or do both have to be on same nagiosxi version?
Once you restore it is going to bring you back down to the version from the backup, but being you are changing operating systems you would have the newer binaries but be on the older Nagios XI system.
this is what I was afraid of, trying to upgrade old server get this
OLD VERSION: 5508
Loaded plugins: fastestmirror
Setting up Update Process
Determining fastest mirrors
Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
OLD VERSION: 5508
Is this server behind a proxy? this error is basically saying that yum cannot reach the epel repository
no proxy we go over this point every time
I'll just keep trying I guess, problem is now I cannot upgrade the old system so cannot migrate to the new server
unless I wipe out the new server and start all over again using 5.5.8, unless I can remove the 5.5.10 and do a full install using 5.5.8?
think I found a snapshot from prior to running install, I'll just roll it back and do 5.5.8
Sounds goodsharding wrote:think I found a snapshot from prior to running install, I'll just roll it back and do 5.5.8
