Cant access nagios core login screen
deepakdeshp
Post by deepakdeshp »
I installed Nagios on Ubuntu server 18.04. I followed following link https://linuxconfig.org/install-nagios- ... difficulty . But Nagios login screen does not appear, please let me know how do I troubleshoot. Only thing I see is the screen divider line which appears
Re: Cant access nagios core login screen
Nagios core doesn't have a login screen, it uses basic authentication and by default would be available at
http://your_host/nagios/
deepakdeshp
scottwilkerson wrote:Nagios core doesn't have a login screen, it uses basic authentication and by default would be available at
Thats the url I used but the first screen does not come up showing devices etc and where I can login as the admin.
I'm not familiar with the URL you posted (it's a 404 error), the official docs are here
https://support.nagios.com/kb/article/n ... ce-96.html
Most notable, did you compile with?
cd /tmp/nagioscore-nagios-4.4.3/
sudo ./configure --with-httpd-conf=/etc/apache2/sites-enabled
and install the apache configs ?
sudo make install-webconf
sudo a2enmod rewrite
sudo a2enmod cgi
