Nagios core mk_livestatus hanging on reload
izghitu
Post by izghitu »
I have latest Nagios core with mk_livestatus working on CentOS 6 64 bit. I use mk_livestatus to get data from Nagios. All works fine when I start Nagios until the moment where a config change is done and I use the init script to reload the Nagios daemon.
What happens after the reload is that any request sent to the mk_livetatus socker including the ones using the unixcat command simply timeout and send back no response.
I have it configured like this:
broker_module=/opt/monitoring/libexec/livestatus.o /opt/monitoring/var/rw/live
event_broker_options=-1
Anyone experienced this in the past?
Please help.
Re: Nagios core mk_livestatus hanging on reload
We do not make livestatus, so may not be of complete help.
Do you get the same issue in you restart nagios?
izghitu
Post by izghitu »
When I fully restart nagios there's no issue, it works just fine
The issue appears only when I use reload.
Ok, thanks, I will try to get support from the creator of livestatus
Also, Core 4.4.3 did fix a related issue, however I am not sure there is a compatible version of livestatus
* Fixed cleanup and deinit of neb modules on reload (#573) (Jake Omann)
https://github.com/NagiosEnterprises/nagioscore
izghitu
Post by izghitu »
scottwilkerson wrote:Also, Core 4.4.3 did fix a related issue, however I am not sure there is a compatible version of livestatus
Thanks, upgrading Nagios fixed the problem
Great!
Locking thread
