Just to let you know, that if you are using an NFS share with nfsnobody:nfsnobody permissions, with the nagios user in the nfsnobody group, the "Test Permission" button returns with:
The directory is likely not writeable by user 'nagios' or group 'nagios' - check permissions.You can close this off too
