Automated reports in Nagios XI
fraguillen
Post by fraguillen »
Good Morning:
I need to mount a report that graphs the consumption of user, system and iowait of the CPU in a stacked chart; the total memory and the one used in another line report, both for a group of hosts or a group of services.
I also need that it can be saved to run it later every 24 hours, if it is possible that it be automated.
How do I do it in Nagios XI?
Best regards...
Re: Automated reports in Nagios XI
You can always add a graph to a dashboard by clicking on the "dashify" icon.
Then, you can go to Dashboards > Your Dashboard, and click on the "Schedule Page" link in the upper right corner.
You can schedule the report to run at a specific time - daily, weekly or monthly.
Note: You need to be using Nagios XI Enterprise Edition in order to use this functionality.
Hope this helps.
fraguillen
Thank you,
I worked the dashboard, we do not have the enterprise license only the standard.
Best regards...
Noted. Let us know if you have any further questions or it is OK to lock this thread. Thanks!
