# service nagios status
● nagios.service - Nagios Core 4.4.3
Loaded: loaded (/lib/systemd/system/nagios.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2019-03-15 11:43:14 CET; 1min 51s ago
Docs: https://www.nagios.org/documentation
Process: 40303 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Process: 40301 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
Main PID: 40305 (nagios)
Tasks: 8 (limit: 19660)
CGroup: /system.slice/nagios.service
├─40305 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
├─40306 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─40307 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─40308 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─40309 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─40310 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
├─40311 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
└─40312 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
mar 15 11:43:14 indispensa nagios[40305]: qh: echo service query handler registered
mar 15 11:43:14 indispensa nagios[40305]: qh: help for the query handler registered
mar 15 11:43:14 indispensa nagios[40305]: wproc: Successfully registered manager as @wproc with query handler
mar 15 11:43:14 indispensa nagios[40305]: wproc: Registry request: name=Core Worker 40306;pid=40306
mar 15 11:43:14 indispensa nagios[40305]: wproc: Registry request: name=Core Worker 40308;pid=40308
mar 15 11:43:14 indispensa nagios[40305]: wproc: Registry request: name=Core Worker 40309;pid=40309
mar 15 11:43:14 indispensa nagios[40305]: wproc: Registry request: name=Core Worker 40311;pid=40311
mar 15 11:43:14 indispensa nagios[40305]: wproc: Registry request: name=Core Worker 40310;pid=40310
mar 15 11:43:14 indispensa nagios[40305]: wproc: Registry request: name=Core Worker 40307;pid=40307
mar 15 11:43:15 indispensa nagios[40305]: Successfully launched command file worker with pid 40312
Unable to get process statusI see this error in nginx logs.
127.0.0.1 - - [15/Mar/2019:11:45:08 +0100] "GET / HTTP/1.0" 500 737798 "-" "check_http/v2.2.1.git (nagios-plugins 2.2.1)"
