Gents,
I am using standard FTP Wizard and it gives me the following error:Socket timeout after 10 seconds
How and where I can increase the timeout or is it related to some other config settings??
Thanks for your help
FTP Check - Executable /usr/bin/lftp is not accessible
Gents,
What can be done to avoid this error while using standard built in FTP Wizard to check for FTP status??
Thanks a lot!
Thanks a lot!
Re: FTP Check - Executable /usr/bin/lftp is not accessible
If you go to
Configure -> Core Config Manager -> Services -> Modify (your ftp service)
Set the following:
Check command = check_ftp
$ARG1$ = -t 30
The 30 can be any number you want and represents the number of seconds before timeout.
Also, if you are getting Executable /usr/bin/lftp is not accessible you might need to run
Set the following:
$ARG1$ = -t 30
yum install lftp -y
