Fusion - custom links and url's
This support forum board is for questions relating to Nagios Fusion.
vishfx
Post by vishfx »
Hi Nagios Team,
Am using Nagios Fusion 4.1.7
I had a few queries :
a) How can I add custom links or Dashboard links to the Fusion homepage , something like below, hope you get the idea.
b) Custom URL dashlet does not seem to work with URL's with basic auth like http://user:[email protected]:8080/mypage.html
I see a blank page.
Kindly assist.
Regards,
Vish.
ssax
Dreams In Code
Re: Fusion - custom links and url's
Post by ssax »
NOTE: Please note that while sometimes we may have time to do stuff like this to help you out to get what you want it should not be expected as the standard level of support, not all of us in the support department know how to develop or have the time to do it.
Please download the attached component that I wrote for you to do what you want.
Then go to Admin > Manage Components:
- Click the Browse button and select the downloaded zip file
- Click the Upload & Install button
Now if you go to the Home menu item you will see 3 new links:
Under Server Status you will see:
Custom Home Link 1
Under Alerts you will see:
Custom Alerts Link 1
Under Visualizations you will see:
Custom Visualization Link 1
To change them, please edit this file and adjust them:
/usr/local/nagiosfusion/html/includes/components/fusioncustomlinks/fusioncustomlinks.inc.php
For example, you could change the top link from this:
$menu->add_link(menu_link(_('Custom Home Link 1'), 'includes/components/fusioncustomlinks/tactical_overview.php'), 'home-server-status');
To this:
$menu->add_link(menu_link(_('My Custom Link'), 'https://username:[email protected]/website/'), 'home-server-status');
Let us know if you have any questions.
Thank you!
cdienger
Post by cdienger »
You could also add a new section to store the custom links:
<?php
register_fusioncustomlinks();
function register_fusioncustomlinks() {
       $component_args = array(
           COMPONENT_TYPE              => COMPONENT,
           COMPONENT_NAME              => 'fusioncustomlinks',
           COMPONENT_TITLE             => _('Fusion Custom Links Component'),
           COMPONENT_VERSION           => '1.0.0',
           COMPONENT_DATE              => '03/26/2019',
           COMPONENT_AUTHOR            => 'Nagios Enterprises, LLC',
           COMPONENT_DESCRIPTION       => _('Provides Custom Menu Entries'),
           COMPONENT_REQUIRES_VERSION  => 4100,
           COMPONENT_FUNCTION          => 'fusioncustomlinks_successful_registration',
   register_component($component_args);
function fusioncustomlinks_successful_registration() {
   register_fusioncustomlinks_callbacks();
function register_fusioncustomlinks_menu($cb, &$menu) {
    $menu->add_section('home', _('stuff'), 'home-stuff');
   $menu->add_link(menu_link(_('Nagios'), 'http://www.nagios.com'), 'home-stuff');
// register callbacks for fusion functionality
function register_fusioncustomlinks_callbacks() {
   register_callback(CALLBACK_MENU_INITIALIZED, 'register_fusioncustomlinks_menu');
I wasn't able to reproduce the problem with the basic auth - are there any special characters in the credentials maybe? Try using the browsers dev tools to monitor the network traffic to see what the issue may be.
vishfx
Post by vishfx »
Thanks, Custom links works !!! I will try it out.
Yes, there are some special chars.
Below is a url which does not work with Custom URL Dashlet :
http://api_key:eyJrIjoiR0ZXZmt1UFc0OEpI ... sk&orgId=1
Also,
The fusion node I use can't talk to the internet.
So, Where can I download all the components listed under "Manage Components" ?
For eg:
Home Page Modification component is 4.0.1 dated 10/04/2017
From where can I download the latest versions ?
Regards,
Vish.
ssax
Dreams In Code
Post by ssax »
Run the URLs through a URL encoder such as this and use the encoded URLs instead:
https://meyerweb.com/eric/tools/dencoder/
Or you could change the code to this:
$menu->add_link(menu_link(_('My Custom Link'), rawurlencode('https://username:[email protected]/website/')), 'home-server-status');
vishfx
Post by vishfx »
ssax wrote:Run the URLs through a URL encoder such as this and use the encoded URLs instead:
I added the rawurlencode, but I get the below error :
The requested URL /nagiosfusion/http://username:[email protected]/website/ was not found on this server.
It seems to be due to "/nagiosfusion/" to the URL.
I also see the below in chrome inspect :
Subresource requests whose URLs contain embedded credentials (e.g. `https://user:pass@host/`) are blocked. See https://www.chromestatus.com/feature/5669008342777856 for more details.
Kindly advise.
Regards,
Vish.
ssax
Dreams In Code
Post by ssax »
Please PM me your file with the changes so that I can review it.
vishfx
Post by vishfx »
Hi Sean,
I'll circle back with that info at a later point. Can live with it for now.
Meanwhile had another requirement,
I want to create a one-click enable/disable Maintenance page for a bunch of HOSTGROUPS/HOSTS
I know this can be achieved using curl call on the below :
http://nagiosxi-lab/nagiosxi/includes/c ... _HOSTGROUP
My question was , how can I deploy a custom 'host_maintenance.php' in the fusion folder "/usr/local/nagiosfusion/html/" for this functionality ?
The idea is to use Fusion as a single point of control.
Is this something that can be done ? Or if you have any other best practice , Kindly Advice ?
Regards,
Vish.
ssax
Dreams In Code
Post by ssax »
You would likely need to write your own component for this, please see here:
https://assets.nagios.com/downloads/nag ... onents.php
vishfx
Post by vishfx »
Thanks Sean.
I will check .
Meanwhile, I have attached a word doc with screenshots and related queries.
fusion-queries.docx
Kindly advise, if these are possible or the only option is to go with own component.
Regards,
Vish.
