We are experiencing issues with many "UNKNOWN" services checks status while monitoring our windows servers
The Nagios log is full of the following error message :
"CURRENT SERVICE STATE: DUUH-XXXX-01.XXXX.corp;Performance - TCPv4/Connection Failures;UNKNOWN;HARD;3;UNKNOWN: Error occurred while running the plugin. Use the verbose flag for more details."
"SERVICE ALERT: XXXX-XX-04.XXX.local;Telnet Socket - pcp+ptr snap_players_count;UNKNOWN;SOFT;1;UNKNOWN: Error occurred while running the plugin. Use the verbose flag for more details.."
It seems the many service checks fails in their first attempt and in the next checks it succeeds.
We WERE NOT able to manually reproduce the failure while using the verbose mode .
On the remote monitored windows server the local NCPA logs is has the following error message :
"2019-03-28 12:35:04,694:ERROR:windowscounters:(-1073738822, 'GetFormattedCounterValue', 'The returned data is not valid.')
Traceback (most recent call last):
File "C:\ncpa\agent\listener\windowscounters.py", line 43, in counter_method
return WindowsCountersNode.get_counter_val(self.name, *args, **kwargs)
File "C:\ncpa\agent\listener\windowscounters.py", line 79, in get_counter_val
_, value = win32pdh.GetFormattedCounterValue(counter, win32pdh.PDH_FMT_DOUBLE)
error: (-1073738822, 'GetFormattedCounterValue', 'The returned data is not valid.')
2019-03-28 12:35:08,891:ERROR:windowscounters:(-1073738822, 'GetFormattedCounterValue', 'The returned data is not valid.')
error: (-1073738822, 'GetFormattedCounterValue', 'The returned data is not valid.') "
The strange thing about the above is that our installation isn't in this location but rather on drive D:\
Our environment is VMWare based
Our current configuration is
Nagios XI version: 5.5.5
Number of services : 6560
Number of Hosts: 456
NCPA version – 2.1.5
We will appreciate your assistance with this problem
Re: "UNKNOWN" services checks status while monitoring our wi
Ignore the internal drive name that NCPA is using, it's unrelated.
Please post the check command that you're running with the passed arguments.
I'm wondering which counter you're checking, maybe you're hitting this:
Try upgrading to NCPA 2.1.6 and see if that resolves the issue, if not, please send us your ncpa.cfg file from the remote system.
What version of the check_ncpa plugin are you using? Please send the output of this command:
https://github.com/NagiosEnterprises/ncpa/issues/520What version of the check_ncpa plugin are you using? Please send the output of this command:
/usr/local/nagios/libexec/check_ncpa.py -VRe: "UNKNOWN" services checks status while monitoring our wi
hi,
thank you for you replay.
with NCPA version 2.1.6 we got the same results.
for your request:
check_ncpa.py, Version 1.1.4
it happens for more than one service, sometimse it is for cpu check with powershell plugin
for example:
-t 'TOKEN' -P 5693 -M 'plugins/PerformanceCounters.ps1' -a 'AuthenticateService,FinancialService'
-t 'TOKEN' -P 5693 -M cpu/percent -w 90 -c 95 -q 'aggregate=avg'
thanks
for your request:
for example:
thanks
Do you see any windows event logs that could be related? Do you have any security software that could be impacting it on the remote system?
hi,
no, no events and no security software on the server
I think you (and another customer) are hitting this:
https://www.reddit.com/r/networking/com ... ort_reuse/
I don't have a solution for you at this time, I've notified the NCPA developer of it and he says it may be the case (we saw the port being reused in packet captures).
Hi talalmog
I am the other Nagios/NCPA user with this issue. Are you still experiencing the problem? If so, maybe we can compare environments to see if there is anything common?
benjaminsmith
Hi @talamog,
Thanks @17g. Yes, please let us know your status, resolved or not?
If you have the time, we are trying to replicate the issue here and Nagio/NCPA logs along with the environment details the Windows server (i.e. version) would be very helpful.
