Imported cfg files but only host name shows in CCM
neshelman
Post by neshelman »
Hi, I used the nagiosxi import tool to import cfg files from our Nagios core server. The converted files in /usr/local/nagios/etc/cfgprep seem OK. All of the hosts appear in the CCM but all of the fields except for Host Name are blank. Did I miss a step? Thanks --Nicholas
Re: Imported cfg files but only host name shows in CCM
This sounds like you imported the service files and not the host files
To prevent errors or misconfigurations, you should import your configurations in an useful order. We recommend importing in the following order:
Commands -> Time Periods -> Contact Templates -> Contacts -> Contact Groups -> Host Templates -> Hosts -> Host Groups -> Service Templates Services -> Service Groups
