Webinjection test Issue/Question
lavosgo
Post by lavosgo »
Hello all,
I need to create (and see if it can be done) some kind of pattern that match a numerical value to be greater than a specific number... can this be done with regex or something else?
In here http://www.webinject.org/manual.html#tcparamverpos it says:
verifypositive
String in response for positive verification. Verification fails if this string does not exist in the HTTP response. This is matched as a Perl regular expression, so you can do some complex verification patterns if you are familar with using regex matching.
Note: Because your verification string is used as a regex, the following characters within it must be escaped with a backslash: {}[]()^$.|*+?\
So overall what I want to do is:
Get XXXX Number in metrics then verify positive if XXXX number is greater than YYYY number.
Thanks!
cdienger
Re: Webinjection test Issue/Question
Post by cdienger »
Regex can be used to find a range. For example, I have a file(index.php) with the following text:
example 100 test
and a simple webinject testcase:
<testcases>
<case
    id="1"
    url="http://192.168.55.3/index.php"
    verifypositive="example [0-9]{1,2} test"
</testcases>
The test fails in this case because the number is 100. Anything between 1-99 would return success.
lavosgo
Post by lavosgo »
Hi!
and what if my file is http://mysite.com:8080/metrics
{"results":
{"CardMigration":{"fifteenMinuteRate":3.91389181659031E-11,"fiveMinuteRate":9.504353538802847E-30,"oneMinuteRate":8.868794373407464E-136,"meanRate":1.4867613403866456E-4,"seventyFifthPercentile":1902.842522,"nintyFifthPercentile":1902.842522,"nintyNinthPercentile":1902.842522,"nintyNinePointNinePercentile":1902.842522,"max":2403.063908,"min":1154.246251,"mean":1902.7940546531531,"median":1902.842522,"count":3},
"CardMigrationFailureRate":{"fifteenMinuteRate":0.0,"fiveMinuteRate":0.0,"oneMinuteRate":0.0,"meanRate":0.0,"count":0},
"ReportCredentialMigration":{"fifteenMinuteRate":1.1798124663085237E-10,"fiveMinuteRate":2.818298571359711E-29,"oneMinuteRate":2.8918378837296734E-135,"meanRate":3.966869878176289E-4,"seventyFifthPercentile":338.641369,"nintyFifthPercentile":338.641369,"nintyNinthPercentile":338.641369,"nintyNinePointNinePercentile":338.641369,"max":2028.339908,"min":8.363896,"mean":225.19234794089792,"median":328.545247,"count":8}
and my verifypositve have to be CardMigration.meanRate < than 100
And the other case: my verifypositve for CardMigrationFailureRate.oneMinuteRate < ReportCredentialMigration.oneMinuteRate
Is that possible?
swolf
Post by swolf »
It looks like you have 2 threads referring to the same issue.
I'm going to lock this one, so we can continue discussion in the other thread.
