NagiosXI upgrade issue
nomlux
Post by nomlux »
Dear support,
Trying to upgrade from NagiosXI 5.4.13 to 5.5.11, in CLI using the command "upgrade", we have the following error:
Checking MySQL status...
MySQL running - continuing...
Setting up Nagios XI database...
ERROR 1007 (HY000) at line 4: Can't create database 'nagiosxi'; database exists
ERROR: Nagios XI database was not setup properly - exiting.
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './B-installxi'
And I have no access anymore to the NagiosXI web site.
I tried the script ./repair_databases.sh but it didn't help.
:roll:
thx,
Olivier M.
Re: NagiosXI upgrade issue
I don't see how it is even possible to have this error if you did run the "upgrade" script... The "B-installxi" is called by the "fullinstall" script.
Can you post the entire upgrade.log? Also run the following command:
history > /tmp/history.txt
and post the history.txt that was generated in the /tmp directory. Thank you!
nomlux
Post by nomlux »
dear all,
the upgrade was successful when following the below procedure from https://assets.nagios.com/downloads/nag ... ctions.pdf
Manual Download
Alternatively, you can upgrade Nagios XI by issuing the following commands in your terminal session:
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgrade
Thanks for your support,
O.
nomlux wrote:dear all,
Manual Download
cd /tmp
cd nagiosxi
./upgrade
O.
great! Glad you got it working
Locking thread
