Nagios server statistics
RIDS_I2MP
Post by RIDS_I2MP »
Hello Team,
Can you please let us know if there is any way to monitor the Nagios XI Server statistics?
We want to monitor Nagios XI Server statistics through Nagios itself and we should get alerts for the same in case of issues.
Also, please let us know the default threshold values for those statistics.
I am attaching the screen shot here for the reference.
Thanks & Regards,
I2MP Team.
Re: Nagios server statistics
At least a couple of these stats are already monitored under localhost, e.g. "Current Load", and "Swap Usage". You could download some 3rd party plugins from the Nagios Exchage, and set up a few more services on localhost.
Here's some "example" configs:
    host_name              localhost
    service_description    Current Load
    use                    local-service
    check_command          check_local_load!5.0,4.0,3.0!10.0,6.0,4.0
    register               1
    host_name                   localhost
    service_description         CPU Stats
    use                         local-service
    check_command               check_linux_stats.pl!-C -w 90 -c 95 -s 5
    register                    1
    command_name    check_linux_stats.pl
    command_line    $USER1$/check_linux_stats.pl $ARG1$
    host_name                   localhost
    service_description         Memory
    use                         xiwizard_generic_service
    check_command               check_mem!-f -C -w 10 -c 5
    register                    1
    command_name    check_mem
    command_line    $USER1$/check_mem.pl $ARG1$
    host_name              localhost
    service_description    Swap Usage
    use                    local-service
    check_command          check_local_swap!20!10
    register               1
You could download the check_linux_stats.pl and check_mem.pl plugins from here:
https://exchange.nagios.org/directory/P ... ts/details
https://github.com/justintime/nagios-pl ... eck_mem.pl
Our documentation on managing plugins in Nagios XI can also be helpful while testing your plugins from the command line, setting up new commands, and services:
Let us know if this helped. Thank you!
