We are using CheckMEM to monitor Physical memory on Windows servers.
Below is command which we are using
COMMAND: /usr/local/nagios/libexec/check_nrpe -H XXXX -t 30 -c CheckMEM -a ShowAll type=physical MaxWarn=80% MaxCrit=90%
OUTPUT: physical: Total: 7.707GB - Used: 2.625GB (34%) - Free: 5.082GB (65%)|'physical'=2.62491GB;6.1653;6.93596;0;7.70663 'physical %'=34%;80;90;0;100
We would like to display performance data which is on GB but not the data in % in Capacity Planning Report.
Is it possible to remove performance data which is displaying in % to avoid extra report in Capacity Planning Report?
Kindly advice.
Query regarding CheckMEM performance data
Re: Query regarding CheckMEM performance data
If you use the check_memory style command and add this option to it
Like the example below
It will filter out the percentage output from the performance data.
Try that to see if it works for you.
"perf-config=%(ignored:true)"Code: Select all
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -t 30 -c check_memory -a type=physical "perf-config=%(ignored:true)"Code: Select all
WARNING: physical = 25.708GB|'physical'=25.70807GB;25.5259;28.71663;0;31.90737Be sure to check out our Knowledgebase for helpful articles and solutions!
We would like to use CheckMEM command as shown below
With this option is it possible to exclude % data in performance output ?
It seems like the "perf-config" option is not available in checkmem (legacy version of check_mem). I don't see any option with this particular plugin that would help you accomplish your goal - see the usage here:
https://docs.nsclient.org/reference/win ... /#checkmem
You may need to change your command to check_memory as tgriep suggested.
