Time issue Nagios XI web interface and CentOS
Lantech
Post by Lantech »
I hope someone can help us with the following issue.
We are having a time issue between the OS en Nagios XI. Referring to the picture you will see a ssh session to our server and the latest events in Nagios XI web interface.
As you can see there is a time difference of one hour.
The following link dint fix the problem.
http://assets.nagios.com/downloads/nagi ... m_Time.pdf
regards,
Lantech
Re: Time issue Nagios XI web interface and CentOS
specify your timezone in your /etc/php.ini file. Newer releases of PHP require this setting for your server to reflect the correct system time and timezone. To change this setting, edit the /etc/php.ini file with the following line:
 date.timezone = Etc/GMT-13
Change the timezone to match your location. These zones are listed at the following URL. PHP Timezones After changing the setting, restart your apache server:
 service httpd restart
Lantech
Post by Lantech »
It fixed the problem! many thanks!
Glad it is resolved.
