[4.4.3] check stale, host crit, doesn't notify service crits
vext
Post by vext »
I can't find what the missing piece is that is preventing ones like this to notify.
Presenting all information on one host/check to simplify.
This one is in hard critical, but current_notification_number=0 (along with last/next notification, etc).
From my attempt to pore over all of this, I don't see what is stopping it from triggering a notification.
Sample logs:
debug output (full, grepping for host/service):
[Tue May  7 16:52:38 2019.418912] [016.1] [pid=112134] Check results for service 'MEMORY' on host 'REDACTED_HOST' are fresh.
[Tue May  7 16:53:38 2019.079681] [016.1] [pid=112134] Check results for service 'MEMORY' on host 'REDACTED_HOST' are stale by 0d 0h 0m 5s (threshold=0d 0h 10m 0s).  Forcing an immediate check of the service...
[Tue May  7 16:53:38 2019.079696] [016.0] [pid=112134] Scheduling a forced, active check of service 'MEMORY' on host 'REDACTED_HOST' @ Tue May  7 16:53:37 2019
[Tue May  7 16:53:38 2019.514079] [008.0] [pid=112134] ** Service Check Event ==> Host: 'REDACTED_HOST', Service: 'MEMORY', Options: 3, Latency: 0.434368 sec
[Tue May  7 16:53:38 2019.514091] [016.0] [pid=112134] Attempting to run scheduled check of service 'MEMORY' on host 'REDACTED_HOST': check options=3, latency=0.434368
[Tue May  7 16:53:38 2019.514120] [016.0] [pid=112134] Checking service 'MEMORY' on host 'REDACTED_HOST'...
[Tue May  7 16:53:53 2019.538269] [016.0] [pid=112134] ** Handling ACTIVE async check result for service 'MEMORY' on host 'REDACTED_HOST' from 'Core Worker 112144'...
[Tue May  7 16:53:53 2019.538284] [016.1] [pid=112134] Check results for service 'MEMORY' on host 'REDACTED_HOST' are stale by 0d 0h 0m 21s (threshold=0d 0h 10m 0s).  Forcing an immediate check of the service...
[Tue May  7 16:53:53 2019.538419] [016.1] [pid=112134] Checking service 'MEMORY' on host 'REDACTED_HOST' for flapping...
[Tue May  7 16:54:38 2019.101310] [016.1] [pid=112134] Check results for service 'MEMORY' on host 'REDACTED_HOST' are fresh.
[Tue May  7 16:55:37 2019.660318] [016.1] [pid=112134] Check results for service 'MEMORY' on host 'REDACTED_HOST' are fresh.
from nagios.log:
[Tue May  7 16:53:38 2019] Warning: The results of service 'MEMORY' on host 'REDACTED_HOST' are stale by 0d 0h 0m 5s (threshold=0d 0h 10m 0s).  I'm forcing an immediate check of the service.
Config information (All except nagios.cfg from objects.cache to ensure combinations of 'use' etc are accounted for):
nagios.cfg (cat nagios.cfg | grep -v -e '^#' -e '^$' | sort):
accept_passive_host_checks=1
additional_freshness_latency=15
admin_email=root@localhost
admin_pager=pagenagios@localhost
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
bare_update_check=0
broker_module=/usr/local/nagios/lib/mk-livestatus/livestatus.o /usr/local/nagios/var/rw/live max_response_size=1048576000
cached_host_check_horizon=15
cached_service_check_horizon=15
cfg_file=/etc/nagios.live/datacat_commands.cfg
cfg_file=/etc/nagios.live/datacat_hostgroups.cfg
cfg_file=/etc/nagios.live/datacat_hosts.cfg
cfg_file=/etc/nagios.live/datacat_servicegroups.cfg
cfg_file=/etc/nagios.live/datacat_services.cfg
cfg_file=/etc/nagios.live/nagios_command.cfg
cfg_file=/etc/nagios.live/nagios_contact.cfg
cfg_file=/etc/nagios.live/nagios_contactgroup.cfg
cfg_file=/etc/nagios.live/nagios_host.cfg
cfg_file=/etc/nagios.live/nagios_hostdependency.cfg
cfg_file=/etc/nagios.live/nagios_hostgroup.cfg
cfg_file=/etc/nagios.live/nagios_service.cfg
cfg_file=/etc/nagios.live/nagios_servicedependency.cfg
cfg_file=/etc/nagios.live/nagios_servicegroup.cfg
cfg_file=/etc/nagios.live/nagios_timeperiod.cfg
cfg_file=/etc/nagios.live/priority_service.cfg
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/var/log/nagios/spool/checkresults
check_service_freshness=1
command_check_interval=-1
command_file=/usr/local/nagios/var/nagios.cmd
daemon_dumps_core=0
date_format=iso8601
debug_file=/var/log/nagios/nagios.debug
debug_level=-1
debug_verbosity=1
enable_embedded_perl=1
enable_environment_macros=0
enable_event_handlers=1
enable_flap_detection=0
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
external_command_buffer_slots=4096
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_archive_path=/var/log/nagios/archives
log_event_handlers=1
log_external_commands=1
log_file=/var/log/nagios/nagios.log
log_host_retries=1
log_initial_states=0
log_notifications=1
log_passive_checks=1
log_rotation_method=h
log_service_retries=1
low_host_flap_threshold=5.0
max_check_result_reaper_time=30
max_concurrent_checks=0
max_debug_file_size=100000000
max_host_check_spread=30
max_service_check_spread=30
nagios_group=nagios
nagios_user=nagios
notification_timeout=30
object_cache_file=/var/log/nagios/objects.cache
obsess_over_hosts=0
obsess_over_services=0
ocsp_timeout=5
p1_file=/usr/sbin/p1.pl
perfdata_timeout=5
precached_object_file=/var/log/nagios/objects.precache
process_performance_data=0
resource_file=/usr/local/nagios/etc/private/resource.cfg
retain_state_information=1
retention_update_interval=1
service_check_timeout=60
service_interleave_factor=s
service_perfdata_file_mode=a
sleep_time=0.25
soft_state_dependencies=0
state_retention_file=/var/log/nagios/retention.dat
status_file=/var/log/nagios/status.dat
status_update_interval=10
temp_file=/var/log/nagios/nagios.tmp
temp_path=/tmp
use_embedded_perl_implicitly=1
use_regexp_matching=0
use_retained_program_state=1
use_syslog=0
use_true_regexp_matching=0
Service Config:
        host_name       REDACTED_HOST
        service_description     MEMORY
        check_period    24x7
        check_command   check_MEMORY
        contact_groups  opsalerts
        notification_period     24x7
        initial_state   o
        importance      0
        check_interval  5.000000
        retry_interval  2.000000
        max_check_attempts      3
        is_volatile     0
        parallelize_check       1
        active_checks_enabled   0
        passive_checks_enabled  1
        obsess  1
        event_handler_enabled   1
        low_flap_threshold      0.000000
        high_flap_threshold     0.000000
        flap_detection_enabled  1
        flap_detection_options  a
        freshness_threshold     600
        check_freshness 1
        notification_options    r,w,u,c
        notifications_enabled   1
        notification_interval   60.000000
        first_notification_delay        0.000000
        stalking_options        n
        process_perf_data       1
        notes_url       REDACTED_RUNBOOK_URL
        retain_status_information       1
        retain_nonstatus_information    1
Contact Configs:
define contactgroup {
        contactgroup_name       opsalerts
        alias   Ops Alert Mailing List
        members opsalerts
define contact {
        contact_name    opsalerts
        alias   opsalerts
        service_notification_period     24x7
        host_notification_period        24x7
        service_notification_options    r,w,u,c
        host_notification_options       r,d,u
        service_notification_commands   notify-service-by-email
        host_notification_commands      notify-host-by-email
        email   REDACTED_EMAIL
        minimum_importance      0
        host_notifications_enabled      1
        service_notifications_enabled   1
        can_submit_commands     1
status.dat extractions:
System status:
info {
        created=1557248618
        version=4.4.3
        last_update_check=1557170975
        update_available=0
        last_version=4.4.3
        new_version=4.4.3
programstatus {
        modified_host_attributes=0
        modified_service_attributes=0
        nagios_pid=112134
        daemon_mode=1
        program_start=1557247713
        last_log_rotation=1557248399
        active_service_checks_enabled=1
        passive_service_checks_enabled=1
        active_host_checks_enabled=1
        passive_host_checks_enabled=1
        obsess_over_hosts=0
        global_host_event_handler=
        global_service_event_handler=
        next_comment_id=945118
        next_downtime_id=170282
        next_event_id=1559258
        next_problem_id=739973
        next_notification_id=505547
        active_scheduled_host_check_stats=224,1491,4555
        active_ondemand_host_check_stats=79,450,1396
        passive_host_check_stats=949,4645,14018
        active_scheduled_service_check_stats=92,141,419
        active_ondemand_service_check_stats=0,0,0
        passive_service_check_stats=4314,21706,65361
        cached_host_check_stats=79,450,1396
        cached_service_check_stats=0,0,0
        external_command_stats=5375,26967,81220
        parallel_host_check_stats=224,1491,4555
        serial_host_check_stats=0,0,0
Host status:
hoststatus {
        host_name=REDACTED_HOST
        modified_attributes=0
        check_command=check-host-alive-production!500.0,10%!900.0,20%!10!1
        check_period=24x7
        notification_period=24x7
        importance=0
        check_interval=5.000000
        retry_interval=1.000000
        event_handler=
        has_been_checked=1
        should_be_scheduled=1
        check_execution_time=20.002
        check_latency=0.354
        check_type=0
        current_state=1
        last_hard_state=1
        last_event_id=1544961
        current_event_id=1558724
        current_problem_id=739598
        last_problem_id=732699
        plugin_output=CRITICAL - Plugin timed out
        long_plugin_output=
        performance_data=
        last_check=1557248400
        next_check=1557248700
        check_options=0
        current_attempt=5
        max_attempts=5
        state_type=1
        last_state_change=1557182576
        last_hard_state_change=1557182896
        last_time_up=1557182576
        last_time_down=1557248400
        last_time_unreachable=0
        last_notification=1557248033
        next_notification=1557255233
        no_more_notifications=0
        current_notification_number=10
        current_notification_id=505545
        notifications_enabled=1
        problem_has_been_acknowledged=0
        acknowledgement_type=0
        active_checks_enabled=1
        passive_checks_enabled=1
        event_handler_enabled=1
        flap_detection_enabled=1
        process_performance_data=1
        obsess=1
        last_update=1557248618
        is_flapping=0
        percent_state_change=0.00
        scheduled_downtime_depth=0
Service status:
servicestatus {
        service_description=MEMORY
        check_command=check_MEMORY
        check_period=24x7
        importance=0
        retry_interval=2.000000
        event_handler=
        has_been_checked=1
        should_be_scheduled=0
        check_execution_time=15.022
        check_latency=0.434
        check_type=0
        current_state=2
        last_hard_state=2
        last_event_id=1492215
        current_event_id=1558908
        current_problem_id=739782
        last_problem_id=708061
        current_attempt=3
        max_attempts=3
        state_type=1
        last_state_change=1557182940
        last_hard_state_change=1557182940
        last_time_ok=1557182940
        last_time_warning=0
        last_time_unknown=0
        last_time_critical=1557248018
        plugin_output=CHECK_NRPE STATE CRITICAL: Socket timeout after 15 seconds.
        long_plugin_output=
        performance_data=
        last_check=1557248018
        next_check=1557248017
        check_options=0
        current_notification_id=0
        last_notification=0
        next_notification=0
        active_checks_enabled=0
        obsess=1
        is_flapping=0
Contact status:
contactstatus {
        contact_name=opsalerts
        host_notification_period=24x7
        service_notification_period=24x7
        last_host_notification=1557248212
        last_service_notification=1557206818
        host_notifications_enabled=1
        service_notifications_enabled=1
Re: [4.4.3] check stale, host crit, doesn't notify service c
The host is in a non-OK state.
Services do not notify if the host is in a non-OK state
vext
Post by vext »
Is that the default? I thought that was controlled by "host_down_disable_service_checks", but I guess I mistakenly under the impression that was off by default.
Am I right in thinking then that setting this to "0" will start notifying?
vext wrote:Is that the default?
yes
vext wrote:I thought that was controlled by "host_down_disable_service_checks", but I guess I mistakenly under the impression that was off by default.
No, setting host_down_disable_service_checks to 1 will stop the checks from even happening.
If you want to send notifications every time a state changes no matter what, you would need to set is_volatile 1
