Problem to install NCPA Agent on RHEL 5
serviciosadmnet
Post by serviciosadmnet »
Hello, i'm triyng to install NCPA agent in a database server with RHEL 5 and i get this error when i run rpm -ivh ncpa-2.1.7.el6.x86_64.rpm:
error: Failed dependencies: rpmlib(FileDigests) <= 4.6.0-1 is needed by ncpa-2.1.7-1-el.6.x86_64
rpmlib(PayloadIsXz) <= 5.2-1 ​is needed ncpa-2.1.7-1-el.6.x86_64​​
Do you know if NCPA agent is compatible with RHEL 5? :(
Re: Problem to install NCPA Agent on RHEL 5
We are no longer building the agent for CentOS/RHEL 5. These operating systems have been supported by NCPA in the past (old version of the agent - 2.0.6).
https://github.com/NagiosEnterprises/ncpa
RHEL 5 reached EOL 2 years ago. Pretty soon, RHEL 6 will be reaching EOL as well. You would need to consider upgrading your operating system in order to be able to use our latest NCPA agent.
serviciosadmnet
ohh, let me take a look, thanks a lot :)
Regards.
Let us know if you have any further questions.
