Nagios Interface API issue
vana1
Post by vana1 »
I am trying to configure Nagios NCPA passive agent for Windows and able to get sorted for most of the things but when i try for Interface with the following syntax getting error
[passive checks]
%HOSTNAME%|CPU Usage = cpu/percent --warning 80 --critical 90 --aggregate avg
%HOSTNAME%|Memory Usage = memory/virtual --units Gi
%HOSTNAME%|interface bytes received = interface/Local%20Area%20Connection/bytes_recv --delta 1 --units K
%HOSTNAME%|interface bytes sent = interface/Local Area Connection/bytes_sent --delta 1 --units K
Error screen attached
Please can anyone help out.
Thanks.
Re: Nagios Interface API issue
Does Local Area Connection exist on this machine? Is it possible that it got renamed? Go to the NCPA API, select the "interface" API Endpoint, and see what are the available interfaces.
BTW, I was not able to recreate the issue in-house. The passive check is working just fine for me. Thank you!
