Couldn't create temporary file. Check that the directory per
s.wiki
Post by s.wiki »
host Performance Graph cannot download CSV files but only for Disk Usage as error below
Couldn't create temporary file. Check that the directory permissions for the /tmp directory are set to 777.
Already do command
chown -R nagios.nagios /usr/local/nagiosxi/html/includes/components/highcharts/exporting-server/temp
chmod -R ug+rwx /usr/local/nagiosxi/html/includes/components/highcharts/exporting-server/temp
Any other solution can try?
Re: Couldn't create temporary file. Check that the directory
Lets make sure apache is part of the nagios group
grep nag /etc/groups
Also, can you show the permissions of these commands
ls -ld /usr/local/nagiosxi/html/includes/components/highcharts/exporting-server/temp
Finally lets make sure selinux is disabled
getenforce
