Change Logs for Configuration Wizards and Components
brucej543
Post by brucej543 »
Were can I locate the change logs for the Configuration Wizards and components, etc so they can be reviewed for changes that would impact our environment?
Just completed update to 5.6.2 in which all the Oracle service checks broke because of the updated Configuration Wizard for all three oracle check_xi_oracleXXXX commands were changed. I was able to correct the issue by modifying the NEW "/usr/local/nagiosxi/etc/configwizards/oracle/oracle" file with the correct PATHs to Oracle lib's
benjaminsmith
Re: Change Logs for Configuration Wizards and Components
Post by benjaminsmith »
Hello @brucej543,
After running check for updates, a download link is provided for the lastest version . In the main directory there is a CHANGELOG.txt file available.
