NagiosXI executes a PS-script on the host on WARN/CRIT-Event
nagchef
Post by nagchef »
Hello guys,
is this possible:
When a service-check result is WARNING or CRITICAL, then Nagios XI should automatically start a powershell-script (maybe through NCPA Agent) on the host, where the problem occurs, to solve the problem.
(the PS-script contains a command to restart an windows service)
In the best case is the problem solved and i don't need to do it manual.
Thank you!
npolovenko
Re: NagiosXI executes a PS-script on the host on WARN/CRIT-E
Post by npolovenko »
Hello, @nagchef. That is possible with the help of event handlers. Please take a look at this article first:
And then check the section called "Event Handler Script Use Case Example".
nagchef
Post by nagchef »
Thank you @npolovenko
Can be closed!
nagchef wrote:Thank you @npolovenko
Can be closed!
Great!
Locking
