I installed Nagios core(fresh install) on my centos 7 Server. But I am having error starting Nagios core. I followed all the procedure as mentioned in
https://assets.nagios.com/downloads/nag ... entos7.pdf
The error are as follows:
[root@localhost ~]# systemctl status nagios.service
● nagios.service - LSB: Starts and stops the Nagios monitoring server
Loaded: loaded (/etc/rc.d/init.d/nagios; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2019-05-30 06:50:28 EDT; 31s ago
Docs: man:systemd-sysv-generator(8)
Process: 5086 ExecStart=/etc/rc.d/init.d/nagios start (code=exited, status=1/FAILURE)
May 30 06:50:28 localhost.localdomain systemd[1]: Starting LSB: Starts and stops the Nagios monitoring server...
May 30 06:50:28 localhost.localdomain nagios[5086]: Executable file /usr/local/nagios/bin/nagios not found. Exiting.
May 30 06:50:28 localhost.localdomain systemd[1]: nagios.service: control process exited, code=exited status=1
May 30 06:50:28 localhost.localdomain systemd[1]: Failed to start LSB: Starts and stops the Nagios monitoring server.
May 30 06:50:28 localhost.localdomain systemd[1]: Unit nagios.service entered failed state.
May 30 06:50:28 localhost.localdomain systemd[1]: nagios.service failed.
Failed to start nagios
Re: Failed to start nagios
Are you sure you ran make install?
It looks like the the init file is there but missing the binary in the expected path
make installscarface998 wrote:May 30 06:50:28 localhost.localdomain nagios[5086]: Executable file /usr/local/nagios/bin/nagios not found. Exiting.
