Tomcat error
Siddharth Hegde
Tomcat error
Post by Siddharth Hegde »
client.cfg
check_command = check_tomcat!80!user!password!10%,10%!5%,5%
I'm getting the following alert for the above
WARNING: memory in use 210 MiB (1708 MiB): Warning: No tomcat connectors matched name =~ /-80$/
80 is suppose to be port number right?
Please help me understand and fix the issue
Regards,
Siddarth Hegde
Pitone_Maledetto
Re: Tomcat error
Post by Pitone_Maledetto »
Hi Siddharth Hegde,
What version of Tomcat are you trying to check?
What plugin do you use? (there are few).
Regards
"It is impossible to work in information technology without also engaging in social engineering"
Jaron Lanier
Siddharth Hegde
Re: Tomcat error
Hi @Pitone_Maledetto
Tomcat version is 7
Plugin used
https://exchange.nagios.org/directory/Plugins/Java-Applications-and-Servers/Apache-Tomcat/check_tomcat-2Epl/details
command.cfg
#Check tomcat service
        command_name    check_tomcat
        command_line   /bin/sh -c  "$USER1$/check_tomcat.pl -H $HOSTADDRESS$ -p $ARG1$ -l $ARG2$ -a $ARG3$ -w $ARG4$ -c $ARG5$"
Regards,
Siddarth Hegde
Pitone_Maledetto
Re: Tomcat error
Assuming check_tomcat.pl,v 1.4
Try to add the following to match all connectors:
-n .
or specify one e.g. -n http-8080
Jaron Lanier
Siddharth Hegde
Re: Tomcat error
I'm getting this message
(No output on stdout) stderr: Port must be a decimal number, eg "-p 8080"
Regards,
Siddarth Hegde
Pitone_Maledetto
Re: Tomcat error
Skip -p since it is optional when not different from default value of 8080.
Is the plugin the latest version?
Have you set the -n has per above?
Please share again your updated command.
Jaron Lanier
cdienger
Re: Tomcat error
Post by cdienger »
Also, make sure you can run the command directly:
/usr/local/nagios/libexec/check_tomcat.pl -H HOSTADDRESS -p 80 -l USER -a PASSWORD -w 10%,10% -c 5%,5%
Siddharth Hegde
Re: Tomcat error
Thanks @Pitone_Maledetto and @cdienger
Tomcat seems to be working now. I removed the plugin and put it back and restarted both servers.
Regards,
Siddarth Hegde
Re: Tomcat error
Siddharth Hegde wrote:Thanks @Pitone_Maledetto and @cdienger
Regards,
Siddarth Hegde
Great!
Locking
ahumandesign.com
enneagrams.com
