I keep getting this error when attempting to apply the config but when I look at line 124, it is correct.
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/COMMON-SERVER.cfg', starting on line 124)
Unable to write config
Re: Unable to write config
Can you show the output of the following
and make sure it is empty
Additionally, you would need to look in the CCM -> Services -> COMMON-SERVER -> "View Config" icon from the CCM, not the file on the server because the file in that path will be reset if the apply configuration fails.
ls -l /usr/local/nagios/etc/importAdditionally, you would need to look in the CCM -> Services -> COMMON-SERVER -> "View Config" icon from the CCM, not the file on the server because the file in that path will be reset if the apply configuration fails.
Did you look at CCM -> Services -> COMMON-SERVER -> "View Config" icon from the CCM and see what object starts on line 124
Kxfrancois
servicegroups hardware-memory
check_command check_xi_service_snmp_win_storage! -C SRVro --v2c -m 'Virtual Memory' -w 90 -c 95 -f!!!!!!!
process_perf_data 1
notifications_enabled 0
_xiwizard windowssnmp
register 1
process_perf_data 1
register 1
Was there a service_description ? I don't see one.
Kxfrancois
You can close this ticket. I figured it out. There was a entry in the cfg file that was missing but it was present in the gui.
Thanks for your help.
Great!Kxfrancois wrote:You can close this ticket. I figured it out. There was a entry in the cfg file that was missing but it was present in the gui.
Glad to hear it is resolved!
Locking
