I'm currently trying to configure my monitoring server to check SSL validity to determine renewal fails.
I've found out that check_http -C allow to check expiration but I can't make it work the way I want.
It seems the command does not take the specified vhost into consideration when it comes to ssl validity checks.
On standard http check, it works perfectly and check the url but on ssl check it automatically checks the first vhost of the server.
Let's admit aaa.com and bbb.com are two website hosted on the same serveur
check_http -C 15 -H aaa.comCode: Select all
check_http -C 15 -H bbb.comOK - Certificate 'aaa.com' will expire on Sun 01 Sep 2019 12:00:24 AM GMT +0000.
Does this come from the way I use the command or is it a bug ?
