I setup NCPA 2.1.7 in Windows 2012R2, sending passive check results to NRDP in NagiosXI 5.6.2.
It all works fine.
But, after upgrade to NagiosXI 5.6.4, the service status stops to receive update from NCPA.
I checked log file ( NCPA/var/log/ncpa_passive.log ), it filled with following lines:
2019-07-16 15:15:55,099:WARNING:nrdp:XML returned did not contain a message, or was malformed.
2019-07-16 15:16:55,506:WARNING:nrdp:XML returned did not contain a message, or was malformed.
2019-07-16 15:17:56,053:WARNING:nrdp:XML returned did not contain a message, or was malformed.
2019-07-16 15:18:56,319:WARNING:nrdp:XML returned did not contain a message, or was malformed.
2019-07-16 15:19:56,678:WARNING:nrdp:XML returned did not contain a message, or was malformed.
It exists even in a fresh installed NagiosXI 5.6.4.
I know the NRDP component is upgraded in 5.6.4.
Is there any way to resolve this problem?
Eyck Lin
NCPA passive check with NRDP doesn't work in NagiosXI 5.6.4
Re: NCPA passive check with NRDP doesn't work in NagiosXI 5.
I was able to recreate the issue. Our developers are looking into this as we speak. I will get back to you as soon as I hear back from our developers. Thank you for reporting this issue!
After upgrade from 5.6.4 to 5.6.5, it's ok now.
NRDP can receive NCPA passive check.
Many Thanks,
Eyck Lin
Many Thanks,
Eyck Lin
Glad to hear everything is working! Closing this thread.
