snmptrapd won't start
seaward1983
Post by seaward1983 »
Linux Distribution and version Redhat 6
64-bit
Manual Install of XI
snmpd is running
snmptt is running
FW rules are correct
Error is 'snmptrapd dead but subsys locked'
**update. Enabled logging - result was
couldn't open udp:162 -- errno 98 ("Address already in use")
I did a netstat on port 162 - and found out nimbus was using the same port. I stopped the nimbus service, and snmptrapd service was able to start.
Is there a way that both can use this port?
Re: snmptrapd won't start
seaward1983 wrote:Is there a way that both can use this port?
You cannot have 2 applications listen on the same port
seaward1983
Thanks! we're done here. :)
seaward1983 wrote:Thanks! we're done here. :)
Great!
Locking
