Turning off port status graph
Somehow the performance graph for port status on our switches got turned on. Wondering if anyone knows where I would turn off the graphing for port status, as it just displays " Performance Data Unavailable" on that graph ( graph 2 in attachment).
Re: Turning off port status graph
What version of XI are you running?
Nagios XI 2011R2.1scottwilkerson wrote:What version of XI are you running?
This is fixed in all versions 2011R2.2 and newer, you can either upgrade or unzip the attached file and copy it to /usr/local/nagiosxi/html/perfgraphs
Thanks for the info, we had another issue that we needed to fix before upgrading, but knowing that will help.
