DNS_Check
nerdintern2019
DNS_Check
Post by nerdintern2019 »
I do not have dns_check built in in my nagios box, and when I tried to install plugins, it still doesnt show up. I found check_dns.c but that file doesnt run dor some reason. I really need help on this.
Thank You,
Re: DNS_Check
/usr/local/nagios/libexec/check_dns comes with the nagios-plugins package
https://support.nagios.com/kb/article.php?id=569
Be sure you look at the Prerequisites based on your OS
You will want to make sure you have the following before compiling (based on CentOS)
yum install -y bind-utils
