Hi everyone,
I have a problem with the upgrade when I'm trying to upgrade from 4.3.4 to 4.4.3.
Can I upgrade directly, or should I first try to install the 4.4.0, and afterwards the patch to 4.4.3?
I read that with the 4.4.0 version, major changes have been implemented.
Long story short - after successful installation of the 4.4.3, the page isn't loading - I do not receive any errors, nor is something written in the error log file..This is starting to drive me nuts.
Thank you for your help.
Best regards,
Ionut Sanda
Nagios Upgrade from 4.3.4 to 4.4.3
bheden
- Product Development Manager
Re: Nagios Upgrade from 4.3.4 to 4.4.3
Which page isn't loading? Which error log file are you referring to? Can you provide us with the upgrade instructions you used?
Can you provide the apache logs and nagios logs, please?
Nagios Enterprises
Senior Developer
Nagios Enterprises
Senior Developer
Hi SandaIonut,
Were you able to get the Nagios page loaded? Definitely check the logs in /var/log/httpd/. If you're not getting any log files there, verifying that Apache is running, maybe even a full restart of the system, would be a good idea.
