Not Receiving Alerts
vaibhav beohar
Post by vaibhav beohar »
Hi Team,
I installed nagios core in my ubuntu server 10.04.3 LTS and my nagios server is working very fine but i am not receiving any alert from nagios,
i am mentioning my all configuration please look into it
[b] cat /etc/postfix/main.cf
[/b]
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
myhostname = wfdpuser-desktop.xyz.com
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = $myhostname, localhost, localhost.localdomain, localhost.$mydomain, $mydomain $myhostname.$mydomain
relayhost = blr-ec-msg04-relay.xyz.com
mynetworks = 127.0.0.0/8 10.207.212.0/24
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
myorigin = /etc/mailname
root@wfdpuser-desktop:~# cat /etc/hosts
127.0.0.1       localhost
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
10.207.212.160 wfdpuser-desktop.xyz.com
10.200.53.98    blr-ec-msg04-relay.xyz.com
root@wfdpuser-desktop:~# ps aux | grep postfix
root     26758  0.0  0.0  37208  2284 ?        Ss   15:40   0:00 /usr/lib/postfix/master
postfix  26761  0.0  0.0  39432  2372 ?        S    15:40   0:00 qmgr -l -t fifo -u
postfix  31270  0.0  0.0  39272  2252 ?        S    17:20   0:00 pickup -l -t fifo -u -c
root     32525  0.0  0.0   7624   908 pts/1    S+   17:45   0:00 grep --color=auto postfix
root@wfdpuser-desktop:~# vi /var/log/mail.info
Apr 19 15:29:46 wfdpuser-desktop postfix/cleanup[25783]: B36E07C1C78: message-id=<20120419095946.B36E07C1C78@wfdpuser-desktop>
Apr 19 15:29:46 wfdpuser-desktop postfix/bounce[25782]: 01C767C1BA5: sender non-delivery notification: B36E07C1C78
Apr 19 15:29:46 wfdpuser-desktop postfix/qmgr[25779]: B36E07C1C78: from=<>, size=2212, nrcpt=1 (queue active)
Apr 19 15:29:46 wfdpuser-desktop postfix/qmgr[25779]: 01C767C1BA5: removed
Apr 19 15:29:46 wfdpuser-desktop postfix/smtp[25784]: B36E07C1C78: to=<[email protected]>, relay=none, delay=0.02, delays=0/0/0.01/0, dsn=5.4.4, status=bounced (Host or domain name not found. Name service error for name=wfdpuser-desktop.xyz.com.xyz.com type=AAAA: Host not found)
Apr 19 15:29:46 wfdpuser-desktop postfix/qmgr[25779]: B36E07C1C78: removed
Apr 19 15:30:28 wfdpuser-desktop postfix/master[25775]: terminating on signal 15
Apr 19 15:31:13 wfdpuser-desktop postfix/master[26112]: daemon started -- version 2.7.0, configuration /etc/postfix
Apr 19 15:39:21 wfdpuser-desktop postfix/master[26112]: terminating on signal 15
Apr 19 15:39:21 wfdpuser-desktop postfix/master[26623]: daemon started -- version 2.7.0, configuration /etc/postfix
Apr 19 15:40:01 wfdpuser-desktop postfix/master[26623]: terminating on signal 15
Apr 19 15:40:02 wfdpuser-desktop postfix/master[26758]: daemon started -- version 2.7.0, configuration /etc/postfix
Apr 19 17:28:34 wfdpuser-desktop postfix/pickup[31270]: D14827C1BBC: uid=0 from=<root>
Apr 19 17:28:34 wfdpuser-desktop postfix/cleanup[31735]: D14827C1BBC: message-id=<[email protected]>
Apr 19 17:28:34 wfdpuser-desktop postfix/qmgr[26761]: D14827C1BBC: from=<[email protected]>, size=486, nrcpt=1 (queue active)
Apr 19 17:28:34 wfdpuser-desktop postfix/local[31738]: D14827C1BBC: to=<[email protected]>, orig_to=<test>, relay=local, delay=0.02, delays=0.01/0/0/0, dsn=5.1.1, status=bounced (unknown user: "test")
Apr 19 17:28:34 wfdpuser-desktop postfix/cleanup[31735]: D4E3D7C1C77: message-id=<[email protected]>
Apr 19 17:28:34 wfdpuser-desktop postfix/bounce[31739]: D14827C1BBC: sender non-delivery notification: D4E3D7C1C77
Apr 19 17:28:34 wfdpuser-desktop postfix/qmgr[26761]: D4E3D7C1C77: from=<>, size=2431, nrcpt=1 (queue active)
Apr 19 17:28:34 wfdpuser-desktop postfix/qmgr[26761]: D14827C1BBC: removed
Apr 19 17:28:34 wfdpuser-desktop postfix/local[31738]: D4E3D7C1C77: to=<[email protected]>, relay=local, delay=0, delays=0/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
Apr 19 17:28:34 wfdpuser-desktop postfix/qmgr[26761]: D4E3D7C1C77: removed
I have made the changes in contact.cfg file in nagios
vaibhav.
wormfishin
Re: Not Receiving Alerts
Post by wormfishin »
If you send mail from the command line of your server, but not nagios, do you receive it?
jsmurphy
Post by jsmurphy »
Do as wormfishin suggested, see what happens if you try to mail from the command line (I'm going to assume it will bounce as the email attempts from Nagios have). Ask your exchange admin or whoever runs your SMTP relay what the requirements are for mailing through it... does it need TLS? authentication? so on and so forth. The basic config you have looks fine so I'm guessing there's a requirement that it hasn't been configured for yet.
vaibhav beohar
NO i am not able to receive mail from my command line as well as my nagios server
i have given all my configuration please look into it.
vaibhav beohar
wormfishin
Is this the email address you are trying to send to or from?
agriffin
Post by agriffin »
Are there any errors in your postfix logs? Also, you could try going through the postfix debugging steps here to help figure out what's wrong.
vaibhav beohar
Hi ,
I tried to update my nagios xi with latest release "Nagios XI 2011R3.1" i am getting following error in console window, but my nagios xi got updated and its working fine.
but i am concern about that error. Please look into it.
*** Configuration summary for ndoutils 1.5.1 05-15-2012 ***:
General Options:
NDO2DB user: nagios
NDO2DB group: nagios
Review the options above for accuracy. If they look okay,
type 'make' to compile the NDO utilities.
cd ./src && make
make[1]: Entering directory `/tmp/nagiosxi/subcomponents/ndoutils/ndoutils-1.5.1/src'
gcc -fPIC -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -c -o io.o io.c
gcc -fPIC -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -c -o utils.o utils.c
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -o file2sock file2sock.c io.o utils.o -lm -lnsl
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -o log2ndo log2ndo.c io.o utils.o -lm -lnsl
make ndo2db-2x
make[2]: Entering directory `/tmp/nagiosxi/subcomponents/ndoutils/ndoutils-1.5.1/src'
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -c -o db.o db.c
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -D BUILD_NAGIOS_2X -c -o dbhandlers-2x.o dbhandlers.c
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -D BUILD_NAGIOS_2X -o ndo2db-2x queue.c ndo2db.c dbhandlers-2x.o io.o utils.o db.o -lnsl -rdynamic -L/usr/lib/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -lssl -lcrypto -lm
make[2]: Leaving directory `/tmp/nagiosxi/subcomponents/ndoutils/ndoutils-1.5.1/src'
make ndo2db-3x
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -D BUILD_NAGIOS_3X -c -o dbhandlers-3x.o dbhandlers.c
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -D BUILD_NAGIOS_3X -o ndo2db-3x queue.c ndo2db.c dbhandlers-3x.o io.o utils.o db.o -lnsl -rdynamic -L/usr/lib/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -lssl -lcrypto -lm
make ndomod-2x.o
gcc -fPIC -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -D BUILD_NAGIOS_2X -o ndomod-2x.o ndomod.c io.o utils.o -shared -lnsl
make ndomod-3x.o
gcc -fPIC -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -D BUILD_NAGIOS_3X -o ndomod-3x.o ndomod.c io.o utils.o -shared -lnsl
gcc -g -O2 -I/usr/include/mysql -DHAVE_CONFIG_H -o sockdebug sockdebug.c io.o utils.o -lm -lnsl
make[1]: Leaving directory `/tmp/nagiosxi/subcomponents/ndoutils/ndoutils-1.5.1/src'
/usr/bin/install -c -m 755 -o root -g root -d /etc/rc.d/init.d
/usr/bin/install -c -m 755 -o root -g root daemon-init /etc/rc.d/init.d/ndo2db
NDOUTILS POST-UPGRADE...
Current database version: 1.5.1
Database already upgraded.
Stopping ndo2db: done.
Starting ndo2db: done.
Running configuration check...done.
Stopping nagios: done.
Starting nagios: done.
NDOUTILS UPGRADED!
Saving old crontab to /tmp/nagios.crontab.orig...
Removing XI cron jobs...
Saving old crontab to /tmp/root.crontab.orig...
Patching NDOUtils...
NDOUtils already patched at level 102
Yum not configured - skipping prereqs update
Copying over new XI directory...
Building latest perms binary...
Updating sequences...
Nagios XI Postgres Database Sequence Information
OLD VALUES
xi_commands_command_id_seq = 839
xi_events_event_id_seq = 50669
xi_meta_meta_id_seq = 50717
xi_options_option_id_seq = 99
xi_sysstat_sysstat_id_seq = 99
xi_usermeta_usermeta_id_seq = 401
xi_users_user_id_seq = 49
NEW VALUES
Installing new PNP templates...
Updating init script...
Enabling large install tweaks...
Fixing config file permissions...
Fixing htpasswd permissions...
Checking group memberships...
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
Installing new XI templates...
URL: http://localhost/nagiosql/index.php
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=qagak6' -O nagiosql.login--2012-06-13 18:39:08-- http://localhost/nagiosql/index.php
Resolving proxy2.mycompany.com... 10.145.22.10
Connecting to proxy2.mycompany.com|10.145.22.10|:8080... connected.
Proxy request sent, awaiting response... 401 Unauthorized
Authorization failed.
NAGIOSQL LOGIN FAILED!
Do i need to update again ???
Vaibhav.
Looks like you are trying to use proxies to localhost.
We have a FAQ that describes how to exclude proxies for localhost
http://support.nagios.com/wiki/index.ph ... th_Proxies
vaibhav beohar
Thanks for your update, its working now.
cheers,
Vaibhav.
vaibhav beohar
Hi One more question.. in my nagios xi home page .. Update check plugin is there.. which is always showing following problem
"Update Check Problem: Last update check failed in nagios xi"
I checked with /usr/local/nagios/libexec location but there is no plugin name as check_xi_updates
How can i make this work???
Thnaks,
