POST check with IAM auth
We are using Postman to run a check on a webAPI hosted in AWS. I want to add this check to Nagios, but I can't for the life of me figure out how to pass the IAM keys in a check_http request. I've tried using Postman to generate the headers then copied those into my request, but nothing works. Is there a module that can do this for me?
Re: POST check with IAM auth
What full command are you using? Is the service expecting a certain header? Here's an example of how to add a header and value:
The "-v" is used to display verbose information including headers that are sent with the request.
./check_http -H www.website.com --header="keys: thisismyiamkeyvalue" -vAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
