Nagios XI perfomance graph shows 0 bandwth for tunnel device
mejokj
Post by mejokj »
Hello
Our Nagios server shows zero bandwidth for most of the tunnel device.
The permission of the rrd file is correct also we have regenerated the rrd and xml file for the service which has an issue. But still shows zero output.
Kindly help us to fix the issue.
mbellerue
Re: Nagios XI perfomance graph shows 0 bandwth for tunnel de
Post by mbellerue »
Is there anything in /usr/local/nagios/var/perfdata.log? We may need to increase logging verbosity. To do that, edit /usr/local/nagios/etc/pnp/process_perfdata.cfg and change LOG_LEVEL = 0 to 1. Then see if we get any additional messages in perfdata.log that could help us.
mejokj
Post by mejokj »
Hi Team,
I have attached the mrtg text file. It may help you to fix the issue.
Please have a look
mbellerue
Post by mbellerue »
I'm not seeing a text file attached to your post, in our team drive, or in my PMs. It may have just failed to attach.
