NagVis: Can't use admin login?
Re: NagVis: Can't use admin login?
Tried this, waited for 5 minutes. Same exact situation: Can't log in directly to /nagios/ or nagvis, I can log into the Nagios XI homepage, and I can get into the Config Core only if I use the first password that I set for the nagiosadmin account, not the current password. No change in my current situation. It appears to be either a .htaccess issue, or a permissions issue.
Just to verify, on your system does httpd run under the apache user?
Looks like it to me:
[root@<server> /]# ps aux | grep apache
apache 5151 0.2 0.9 52692 19852 ? S 14:22 0:27 /usr/sbin/httpd
apache 5152 0.2 0.9 49296 19212 ? S 14:22 0:27 /usr/sbin/httpd
apache 5153 0.2 0.9 51668 19424 ? S 14:22 0:27 /usr/sbin/httpd
apache 5154 0.2 0.9 52628 19496 ? S 14:22 0:28 /usr/sbin/httpd
apache 5155 0.2 0.9 51668 19408 ? S 14:22 0:28 /usr/sbin/httpd
apache 5156 0.2 0.9 51668 19412 ? S 14:22 0:28 /usr/sbin/httpd
apache 5157 0.2 0.9 52692 19596 ? S 14:22 0:27 /usr/sbin/httpd
apache 5158 0.2 0.9 51604 19316 ? S 14:22 0:28 /usr/sbin/httpd
apache 8041 0.2 0.9 51604 18988 ? S 14:27 0:27 /usr/sbin/httpd
apache 20144 0.2 0.9 49296 19020 ? S 14:48 0:24 /usr/sbin/httpd
apache 20355 0.2 0.9 51668 19456 ? S 14:48 0:23 /usr/sbin/httpd
root 27463 0.0 0.0 4332 756 pts/0 S+ 17:51 0:00 grep apache
I've got another idea, I'll report back shortly.
Ok, got it: I was thinking, what's the only thing I haven't changed....the computer I was testing everything out on. I went to a different computer and NagVis worked perfectly. I rebooted my computer, and bam, now it's working on mine as well. I'm guessing cookies were getting stored and not deleted when I closed my browser, so I assumed everything was on the clear. If you have any other questions or concerns, let me know!
Whew....way too much work for the old Windows solution :p
