Check Windows service if it is running
HaschkeD
Post by HaschkeD »
i use NagiosQL and i have this command to check if a service is down:
$USER1$/check_nt -t 90 -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
$ARG1$ SERVICESTATE -l "NtFrs" -d SHOWALL
Nagios go in a red state if service is down. Is it possible that i change the command that Nagios go in a red state if the service is up?
Regards
Dennis
Re: Check Windows service if it is running
You would need to create a negated command such as the following, and change this service to use the new command with the same arguments
$USER1$/negate -s $USER1$/check_nt -t 90 -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
https://support.nagios.com/kb/article.p ... ce_stopped
ahumandesign.com
enneagrams.com
HaschkeD
Post by HaschkeD »
Works fine...thanks…...
HaschkeD wrote:Works fine...thanks…...
Great!
Locking
ahumandesign.com
enneagrams.com
