Monitor disk space by specific value
alex3105
Post by alex3105 »
Good Morning,
I want to monitor the free disk space of my Windows and Linux servers but configure the alerts when it is met not in percentage but in specific value in Gb of 5 for warning and 10 for critical.
I have reviewed the url https://support.nagios.com/kb/article.p ... free_value, in the Disk Free Space - Specified value section and I have found some plugins that can solve my problem but nevertheless I have the following doubts:
1. Can I not add my remote host with the check_disk plugin? I mean it doesn't have the host parameter or how I add it.
2. I installed nrpe by following the url: https://support.nagios.com/kb/article.php?id=515 but when executing the test command I get
./check_nrpe -H 192.168.32.16 -c check_drivesize -a drive=C: 'warning=free<10G' 'critical=free<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${free} free / ${size} total}' top-syntax='${status}: ${problem_list}'
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
With the same check_nrpe the following commands applied to a remote computer I get an answer
./check_nrpe -H 192.168.32.16 -c check_cpu
./check_nrpe -H 192.168.32.16 -c check_memory
I would be grateful if you could indicate to me what would be the best way to monitor the disk of my equipment, or the plugin with some suitable argument.
Best regards
mbellerue
Re: Monitor disk space by specific value
Post by mbellerue »
1. The check_disk plugin is meant to be run on the remote host itself, and is called by an agent like NRPE or NCPA. It looks like you have NRPE installed already, so let's focus on that agent.
2. You linked to the document for installing NRPE from source, but it looks like you are trying to monitor a Windows machine. Is the remote machine a Windows machine? Is it running NSClient++ to provide the NRPE service?
alex3105
Post by alex3105 »
The remote computer if it is a Windows, I am also using NSclient by enabling the Enable NRPE Server option (check_nrpe).
Best Regards,
mbellerue
Post by mbellerue »
On your remote system, in the nsclient.ini file you should have a section titled [/settings/NRPE/server]. Make sure you have these entries.
allow arguments = 1
allow nasty characters = true
Restart the NSClient service, and then try your check_nrpe command again.
alex3105
Post by alex3105 »
Make the changes but now I get this:
[root@localhost libexec]# ./check_nrpe -H 192.168.32.16 -c check_drivesize -a drive=C: 'warning=free<10G' 'critical=free<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${free} free / ${size} total}' top-syntax='${status}: ${problem_list}'
CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with 192.168.32.16: 1
I have verified that there is an rule in my firewall of my pc that allows access to port 5666, In addition to some possible solutions of:
https://support.nagios.com/forum/viewto ... =6&t=50275
https://support.nagios.com/forum/viewto ... =7&t=49392
command_name check_nrpe
command_line USER1$/check_nrpe -H $HOSTADDRESS$ -2 -t 30 -c $ARG1$ $ARG2$
[root@localhost libexec]# /usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
NRPE v3.2.1
[root@localhost libexec]# ps axuw | grep nrpe
nagios 992 0.0 0.1 42784 2748 ? Ss 21:29 0:00 /usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -f
[root@localhost libexec]# netstat -apt | grep nrpe
tcp 0 0 0.0.0.0:nrpe 0.0.0.0:* LISTEN 992/nrpe
tcp6 0 0 [::]:nrpe [::]:* LISTEN 992/nrpe
[root@localhost libexec]# service nrpe restart; tail -f /var/log/messages
Redirecting to /bin/systemctl restart nrpe.service
Oct 14 23:01:46 localhost nagios: HOST NOTIFICATION: user3ctx;MGMT;DOWN;notify-host-by-email-html;CRITICAL - Host Unreachable (192.168.32.10)
Oct 14 23:02:14 localhost nagios: HOST NOTIFICATION: user1ctx;ENDIAN;DOWN;notify-host-by-email-html;CRITICAL - Host Unreachable (192.168.32.15)
Oct 14 23:02:14 localhost nagios: HOST NOTIFICATION: user3ctx;ENDIAN;DOWN;notify-host-by-email-html;CRITICAL - Host Unreachable (192.168.32.15)
Oct 14 23:02:14 localhost nagios: HOST NOTIFICATION: user2ctx;ENDIAN;DOWN;notify-host-by-email-html;CRITICAL - Host Unreachable (192.168.32.15)
Oct 14 23:02:14 localhost nagios: HOST NOTIFICATION: user4ctx;ENDIAN;DOWN;notify-host-by-email-html;CRITICAL - Host Unreachable (192.168.32.15)
Oct 14 23:04:23 localhost nrpe[992]: Caught SIGTERM - shutting down...
Oct 14 23:04:23 localhost systemd: Stopping Nagios Remote Plugin Executor...
Oct 14 23:04:23 localhost nrpe[992]: Daemon shutdown
Oct 14 23:04:23 localhost systemd: Started Nagios Remote Plugin Executor.
Oct 14 23:04:23 localhost systemd: Starting Nagios Remote Plugin Executor...
Oct 14 23:04:23 localhost nrpe[20625]: Starting up daemon
Oct 14 23:04:23 localhost nrpe[20625]: Server listening on 0.0.0.0 port 5666.
Oct 14 23:04:23 localhost nrpe[20625]: Server listening on :: port 5666.
Oct 14 23:04:23 localhost nrpe[20625]: Warning: Daemon is configured to accept command arguments from clients!
Oct 14 23:04:23 localhost nrpe[20625]: Listening for connections on port 5666
Oct 14 23:04:23 localhost nrpe[20625]: Allowing connections from: 127.0.0.1,::1,192.168.32.14
[root@localhost libexec]# rpm -qa | grep openssl
xmlsec1-openssl-1.2.20-7.el7_4.x86_64
openssl-1.0.2k-12.el7.x86_64
openssl-devel-1.0.2k-12.el7.x86_64
openssl-libs-1.0.2k-12.el7.x86_64
Best Regards
mbellerue
Post by mbellerue »
Can you post the nsclient.ini file from your remote Windows machine? It should be located in C:\Program Files\NSClient++\nsclient.ini.
alex3105
Post by alex3105 »
A thousand apologies for the delay .. I attach the requested file
Support Edit: nsclient.log and nsclient.ini downloaded and shared with team.
mbellerue
Post by mbellerue »
Perfect, thank you!
Under [/settings/NRPE/server], if you change verify mode from peer-cert to either peer or none, you should be able to complete your service check. More information can be had here,
https://docs.nsclient.org/reference/win ... ify-mode_1
alex3105
Post by alex3105 »
Make the change and restart the NsClient service and even restart my computer but the same error message appears, could you please help me.
nsclient.log
(2.63 KiB) Downloaded 297 times
nsclient.ini
(1.06 KiB) Downloaded 306 times
mbellerue
Post by mbellerue »
Oh, there was an extra verify mode=peer-cert. I've removed that. Try using the config file attached to this post.
nsclient.ini
(1.01 KiB) Downloaded 234 times
