Guys,
I am using check-host-alive which is using check_ping (2.2.1) & have set the host_check_timeout=60 in nagios.cfg.
command_name check-host-alive
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
Sometimes Nagios report host as "DOWN" with message "Plugin time out" during which the server monitored is actually UP.
Any thoughts on how to resolve this?
Plugin time out - check_ping when host is not DOWN
benjaminsmith
Re: Plugin time out - check_ping when host is not DOWN
Try updating your check command with the -t 60 timeout option on the plugin.
check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5 -t 60
