Monitoring VMware With Nagios XI
Re: Monitoring VMware With Nagios XI
It is at first it was not. Problem persists, and yes I do know and was using enablerepo=BLAH. All my repos (with the exception of the primary OS are set to disabled).
[nagios-base]
name=Nagios
baseurl=http://IROCK/repo/NAGIOS/7/nagios-base/
enabled=0
gpgcheck=0
#gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NAGIOS-V2
[nagiosxi-deps]
name=Nagios XI Dependencies
baseurl=http://UROLL/repo/NAGIOS/7/nagiosxi-deps/
enabled=0
gpgcheck=0
Not sure why we are even going down the repo route, it has NOTHING to do with this issue I am seeing.
[nagios-base]
name=Nagios
enabled=0
gpgcheck=0
[nagiosxi-deps]
enabled=0
gpgcheck=0
I went there because you asked this:
gary80918 wrote:That seems to easy, to really be the problem. The only repo I am not yet “able/or sure how” to update is the nagiosxi repo.
root@hpsatvld5302:~ # yum repolist
Loaded plugins: langpacks
repo id repo name status
epel local files for EPEL repo RHEL 7Server-x86_64 13,454
nagios-base Nagios 96
nagiosxi-deps Nagios XI Dependencies 31
repolist: 13,581
You have mail in /var/spool/mail/root
I think I got a little to verbal with the repo errors. They are fixed and unrelated.
My problem still winds up at:
Fetching with LWP:
http://10.200.1.254/repo/cpan/CPAN/modu ... st.data.gz
Reading '/root/.cpan/sources/modules/03modlist.data.gz'
DONE
Writing /root/.cpan/Metadata
App::cpanminus is up to date (1.7044).
root@hpsatvld5302:~ # cpanm --notest Module::Build Crypt::SSLeay
! Finding Module::Build on cpanmetadb failed.
--> Working on Module::Build
Fetching http://10.200.1.254/repo/cpan/CPAN/auth ... 229.tar.gz ... OK
Configuring Module-Build-0.4229 ... OK
Building Module-Build-0.4229 ... OK
Successfully reinstalled Module-Build-0.4229
! Finding Crypt::SSLeay on cpanmetadb failed.
--> Working on Crypt::SSLeay
Fetching http://10.200.1.254/repo/cpan/CPAN/auth ... .72.tar.gz ... OK
Configuring Crypt-SSLeay-0.72 ... Configuring Crypt-SSLeay failed.
You can s)kip, r)etry, e)xamine build log, or l)ook ?
Any ideas, direction, tests?
Fetching with LWP:
DONE
For some reason this is failing
this is the output of a normal online system
[root@nagiosxi ~]# cpanm --notest Module::Build Crypt::SSLeay
Fetching http://www.cpan.org/authors/id/L/LE/LEONT/Module-Build-0.4229.tar.gz ... OK
==> Found dependencies: Module::Metadata, version, CPAN::Meta, Perl::OSType
--> Working on Module::Metadata
Fetching http://www.cpan.org/authors/id/E/ET/ETHER/Module-Metadata-1.000037.tar.gz ... OK
Configuring Module-Metadata-1.000037 ... OK
==> Found dependencies: version
--> Working on version
Fetching http://www.cpan.org/authors/id/J/JP/JPEACOCK/version-0.9924.tar.gz ... OK
Configuring version-0.9924 ... OK
Building version-0.9924 ... OK
Successfully installed version-0.9924
Building Module-Metadata-1.000037 ... OK
Successfully installed Module-Metadata-1.000037
--> Working on CPAN::Meta
Fetching http://www.cpan.org/authors/id/D/DA/DAGOLDEN/CPAN-Meta-2.150010.tar.gz ... OK
Configuring CPAN-Meta-2.150010 ... OK
==> Found dependencies: CPAN::Meta::YAML, JSON::PP, CPAN::Meta::Requirements
--> Working on CPAN::Meta::YAML
Fetching http://www.cpan.org/authors/id/D/DA/DAGOLDEN/CPAN-Meta-YAML-0.018.tar.gz ... OK
Configuring CPAN-Meta-YAML-0.018 ... OK
==> Found dependencies: JSON::PP
--> Working on JSON::PP
Fetching http://www.cpan.org/authors/id/I/IS/ISHIGAKI/JSON-PP-4.04.tar.gz ... OK
Configuring JSON-PP-4.04 ... OK
Building JSON-PP-4.04 ... OK
Successfully installed JSON-PP-4.04
Building CPAN-Meta-YAML-0.018 ... OK
Successfully installed CPAN-Meta-YAML-0.018
--> Working on CPAN::Meta::Requirements
Fetching http://www.cpan.org/authors/id/D/DA/DAGOLDEN/CPAN-Meta-Requirements-2.140.tar.gz ... OK
Configuring CPAN-Meta-Requirements-2.140 ... OK
Building CPAN-Meta-Requirements-2.140 ... OK
Successfully installed CPAN-Meta-Requirements-2.140
Building CPAN-Meta-2.150010 ... OK
Successfully installed CPAN-Meta-2.150010
--> Working on Perl::OSType
Fetching http://www.cpan.org/authors/id/D/DA/DAGOLDEN/Perl-OSType-1.010.tar.gz ... OK
Configuring Perl-OSType-1.010 ... OK
Building Perl-OSType-1.010 ... OK
Successfully installed Perl-OSType-1.010
==> Found dependencies: ExtUtils::CBuilder, TAP::Harness
--> Working on ExtUtils::CBuilder
Fetching http://www.cpan.org/authors/id/A/AM/AMBS/ExtUtils-CBuilder-0.280231.tar.gz ... OK
Configuring ExtUtils-CBuilder-0.280231 ... OK
==> Found dependencies: IPC::Cmd
--> Working on IPC::Cmd
Fetching http://www.cpan.org/authors/id/B/BI/BINGOS/IPC-Cmd-1.04.tar.gz ... OK
Configuring IPC-Cmd-1.04 ... OK
==> Found dependencies: Locale::Maketext::Simple, Module::Load::Conditional, Params::Check
--> Working on Locale::Maketext::Simple
Fetching http://www.cpan.org/authors/id/J/JE/JESSE/Locale-Maketext-Simple-0.21.tar.gz ... OK
Configuring Locale-Maketext-Simple-0.21 ... OK
Building Locale-Maketext-Simple-0.21 ... OK
Successfully installed Locale-Maketext-Simple-0.21
--> Working on Module::Load::Conditional
Fetching http://www.cpan.org/authors/id/B/BI/BINGOS/Module-Load-Conditional-0.70.tar.gz ... OK
Configuring Module-Load-Conditional-0.70 ... OK
==> Found dependencies: Module::Load, Module::CoreList, Params::Check
Fetching http://www.cpan.org/authors/id/B/BI/BINGOS/Module-Load-0.34.tar.gz ... OK
Configuring Module-Load-0.34 ... OK
Building Module-Load-0.34 ... OK
Successfully installed Module-Load-0.34
--> Working on Module::CoreList
Fetching http://www.cpan.org/authors/id/B/BI/BINGOS/Module-CoreList-5.20191110.tar.gz ... OK
Configuring Module-CoreList-5.20191110 ... OK
Building Module-CoreList-5.20191110 ... OK
Successfully installed Module-CoreList-5.20191110
--> Working on Params::Check
Fetching http://www.cpan.org/authors/id/B/BI/BINGOS/Params-Check-0.38.tar.gz ... OK
Configuring Params-Check-0.38 ... OK
Building Params-Check-0.38 ... OK
Successfully installed Params-Check-0.38
Building Module-Load-Conditional-0.70 ... OK
Successfully installed Module-Load-Conditional-0.70
Building IPC-Cmd-1.04 ... OK
Successfully installed IPC-Cmd-1.04
Building ExtUtils-CBuilder-0.280231 ... OK
Successfully installed ExtUtils-CBuilder-0.280231
--> Working on TAP::Harness
Fetching http://www.cpan.org/authors/id/L/LE/LEONT/Test-Harness-3.42.tar.gz ... OK
Configuring Test-Harness-3.42 ... OK
Building Test-Harness-3.42 ... OK
Successfully installed Test-Harness-3.42 (upgraded from 3.28)
Successfully installed Module-Build-0.4229
Fetching http://www.cpan.org/authors/id/N/NA/NANIS/Crypt-SSLeay-0.72.tar.gz ... OK
==> Found dependencies: Try::Tiny, Path::Class
--> Working on Try::Tiny
Fetching http://www.cpan.org/authors/id/E/ET/ETHER/Try-Tiny-0.30.tar.gz ... OK
Configuring Try-Tiny-0.30 ... OK
Building Try-Tiny-0.30 ... OK
Successfully installed Try-Tiny-0.30 (upgraded from 0.12)
--> Working on Path::Class
Fetching http://www.cpan.org/authors/id/K/KW/KWILLIAMS/Path-Class-0.37.tar.gz ... OK
Configuring Path-Class-0.37 ... OK
Building Path-Class-0.37 ... OK
Successfully installed Path-Class-0.37
Configuring Crypt-SSLeay-0.72 ... OK
Building Crypt-SSLeay-0.72 ... OK
Successfully installed Crypt-SSLeay-0.72 (upgraded from 0.64)
19 distributions installed
You have new mail in /var/spool/mail/root
[root@nagiosxi ~]#
Yes, that is my problem. I build in an online environment it works perfectly. I build in an offline environment it does not. Any ideas that could get me past the Crype::SSLeay?
Right now (and not my favorite idea) I am thinking the best way to start our NAGIOS XI is to build it in an on line environment and then move to our offline environment. The downside to that is I will have to come up with a way keep the already in use server up to the most current level.
One option would be to attempt to download the source and compile it
download this and move it to the server
https://cpan.metacpan.org/authors/id/N/ ... .72.tar.gz
then
then
tar xzf Crypt-SSLeay-0.72.tar.gz
cd Crypt-SSLeay-0.72
perl Makefile.PL
make
make test
make install
If this is the case I would recommend still following the offline install process (even when online), then just add the VMWare packages using the online cpan repositores, then take it offline.gary80918 wrote:Right now (and not my favorite idea) I am thinking the best way to start our NAGIOS XI is to build it in an on line environment and then move to our offline environment. The downside to that is I will have to come up with a way keep the already in use server up to the most current level.
This will allow you to continue to follow the procedure for upgrading Nagios XI in an offline environment.
Fixed, the problem was I did not have:
yum install openssl-devel
installed.
installed.
Great!gary80918 wrote:Fixed, the problem was I did not have:
installed.
Locking thread
