Hi Team,
Could you please send the nsclient.cfg explanation documents, which settings we should use for what.
Do we have any document for nsclient config explanation
grayloglearn
Re: Do we have any document for nsclient config explanation
Please note that nsclient++ is a third party client and our documentation will usually focus on just getting it to work with our software. If you need specifics regarding nsclient++ the it would be best to search their site/forums.
That said, here are few docs you may find useful:
https://docs.nsclient.org/tutorial/
