VERITAS-APPLIANCE-MONITORING-MIB DEFINITIONS ::= BEGIN
IMPORTS
DisplayString, mib-2 FROM RFC1213-MIB
enterprises, OBJECT-TYPE, NOTIFICATION-TYPE, MODULE-IDENTITY FROM SNMPv2-SMI;
applianceMonitoringMib MODULE-IDENTITY
LAST-UPDATED "2016083000Z"
ORGANIZATION "Veritas Technologies LLC"
CONTACT-INFO "500 East Middlefield Road
Mountain View, CA 94043 US
Subject: appliance.mib"
DESCRIPTION "The MIB module for Veritas Appliance Monitoring"
REVISION "201609060000Z"
DESCRIPTION "Changed symc strings to vrts."
::= { products 9 }
veritassoftware OBJECT IDENTIFIER ::= { enterprises 48328 }
products OBJECT IDENTIFIER ::= { veritassoftware 3 }
systems OBJECT IDENTIFIER ::= { applianceMonitoringMib 1 }
software OBJECT IDENTIFIER ::= { applianceMonitoringMib 2 }
-- system traps
vrtssystemName OBJECT-TYPE
SYNTAX DisplayString (SIZE(0..80))
MAX-ACCESS read-only
STATUS current
DESCRIPTION "System Name"
::= { systems 1 }
vrtsfanTrap NOTIFICATION-TYPE
OBJECTS { vrtssystemName }
STATUS current
DESCRIPTION "Traps fan failures"
::= { systems 3 }
vrtspowerTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps power failures"
::= { systems 4 }
vrtsfibrechannelTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps FibreChannel failures"
::= { systems 5 }
vrtstemperatureTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps temperature failures"
::= { systems 6 }
vrtscpuTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps cpu failures"
::= { systems 7 }
vrtsdiskTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps disk failures"
::= { systems 8 }
vrtsraidgroupTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps raid failures"
::= { systems 9 }
vrtsenclosurefanTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps enclosure fan failures"
::= { systems 10 }
vrtsenclosurepowerTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps enclosure power failures"
::= { systems 11 }
vrtsenclosuretemperatureTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps enclosure temperature failures"
::= { systems 12 }
vrtsenclosurediskTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps enclosure disk failures"
::= { systems 13 }
vrtsadapterTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps adapter failures"
::= { systems 14 }
vrtsfirmwareTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps firmware failures"
::= { systems 15 }
vrtspciTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps pci failures"
::= { systems 16 }
vrtsnetworkcardTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps network card failures"
::= { systems 17 }
vrtsvolumeTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps volume failures"
::= { systems 18 }
vrtsbbuTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps BBU failures"
::= { systems 19 }
vrtsconnectionTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps connection failures"
::= { systems 20 }
vrtspartitionTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Partition alert traps"
::= { systems 21 }
vrtsstoragestatusTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps StorageArray HealthStatus failures"
::= { systems 22 }
vrtsdimmTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps Dimm failures"
::= { systems 23 }
vrtsiscsiTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps Iscsi failures"
::= { systems 24 }
vrtsethernetTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Traps Ethernet failures"
::= { systems 25 }
-- software traps
vrtsfailedJobsTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Job failures Trap"
::= { software 1 }
vrtsprocessTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Processes stopped traps"
::= { software 2 }
vrtsdiskSpaceTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Low disk space traps"
::= { software 3 }
vrtssoftwareUpdateSuccessTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Software update success trap"
::= { software 4 }
vrtssoftwareUpdateFailedRollbackSuccessTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Software update failed but rollback was successful trap"
::= { software 5 }
vrtssoftwareUpdateFailedRollbackFailedTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Software update and rollback failed trap"
::= { software 6 }
vrtsrollbackSuccessTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Software rollback success trap"
::= { software 7 }
vrtsrollbackFailedTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Software rollback failed trap"
::= { software 8 }
vrtsclusterStateTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Cluster node failed trap"
::= { software 9 }
vrtsdiskPerfTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Disk performance alert trap"
::= { software 10 }
vrtscollectorserviceTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "Collector plugin loading failed trap"
::= { software 11 }
vrtshaclusternameTrap NOTIFICATION-TYPE
STATUS current
DESCRIPTION "HA cluster name trap"
::= { software 12 }
END
