Symantec Backup Remote Agent for Linux or Unix Servers
Post by Box293 »
I recently needed to configure Symantec Backup Exec 2010 to backup a Nagios XI server. I thought I would post the steps I needed to perform to make it all work.
  • Open a console session or a putty session to the Nagios XI host
    Type yum -y install compat-libstdc++* and press Enter
    This will install some pre-requisites
Install the Remote Agent as per the instructions in the Backup Exec help file
Now we just need to configure the firewall
  • Type iptables -I INPUT -p tcp --dport 10000 -j ACCEPT and press Enter
    Type iptables -I INPUT -p tcp --dport 1025:65535 -j ACCEPT and press Enter
    Type /sbin/service iptables save and press Enter
    You can now exit your console/putty session
You should be able to add your Nagios XI server to your Backup Exec Linux/Unix Servers (Favourite Resources).
tonyyarusso
Re: Symantec Backup Remote Agent for Linux or Unix Servers
Post by tonyyarusso »
Thanks for the tip!
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
