Mib uploaded but still in unknown trap
biswajit.banerjee
Post by biswajit.banerjee »
Uploaded the mib with OID 1.3.6.1.4.1.2011.5.25.136.1.6.8 and shows in /etc/snmptt/snmptt.conf.nxti
EVENT hwDot3ahEfmRemoteDyingGaspEvent 1.3.6.1.4.1.2011.5.25.136.1.6.8 "status events" critical
FORMAT Received trap "$N" with variables "$+*"
EXEC php /usr/local/nagiosxi/scripts/nxti.php --event_name="$N" --event_oid="$i" --numeric_oid="$o" --symbolic_oid="$O" --community="$C" --trap_hostname="$R" --trap_ip="$aR" --agent_hostname="$A" --agent_ip="$aA" --category="$c" --severity="$s" --uptime="$T" --datetime="$x $X" --unixtime="$@" --bindings="$+*"
SDESC
EDESC
But Still going to snmpttunknown.log
04:50:12 20191202 : Unknown trap (.1.3.6.1.4.1.2011.5.25.136.1.6.8) received from 10.254.0.166 at:
Value 0: 10.254.0.166
Value 1: 10.254.0.166
Value 2: 133:20:51:51.21
Value 3: .1.3.6.1.4.1.2011.5.25.136.1.6.8
Value 4: 10.254.0.166
Value 5:
Value 6:
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: .1.3.6.1.4.1.2011.5.25.136.1.2.2.3.1.1.6=10:BE:F5:C7:92:A9
Ent Value 1: .1.3.6.1.2.1.2.2.1.2.6=XGigabitEthernet0/0/1
The Mib is attached
Can you please guide where is the issue ?
TIA
Re: Mib uploaded but still in unknown trap
Can you run the following 3 commands as root.
tar cvfz /tmp/snmp.tgz /etc/snmp/*
tar cvfz /tmp/sharesnmp.tgz /usr/share/snmp/mibs/* --dereference
tar cvfz /tmp/snmplog.tgz /var/log/snmptt/*
Then post these 3 files so we can check the settings and the MIB files for any errors on why the Trap is still showing up in the unknown log.
/tmp/snmp.tgz
/tmp/sharesnmp.tgz
/tmp/snmplog.tgz
biswajit.banerjee
Thanks for Reply
Please find the requested files attached
I see the OID is duplicated in the snmptt.conf.nxti file so you should update the Defined Traps and remove one of the entries. See the entries below.
EVENT portinterfacedown 1.3.6.1.4.1.2011.5.25.136.1.6.8 "status events" critical
SDESC
interface down
EDESC
SDESC
EDESC
The HUAWEI-ETHOAM-MIB.mib file requires other MIB files to be loaded on the server and some of them are missing which is causing the trap to be unknowm.
Find and upload the following MIB to the server and then restart snmptt and see if the trap is received.
HUAWEI-MIB
P-BRIDGE-MIB
Q-BRIDGE-MIB
biswajit.banerjee
Thanks for Update .
Can I remove the duplicate OID entry directly editing the file or I need to follow some procedure ? Please mention the procedure if any .
For Missing MIB , will update when received from the Vendor .
The duplicated OID has to be removed from the SNMP Trap Interface menu.
If you edit the file directly, the settings from the SNMP Trap menu will overwrite it and put it back.
Just click on the Defined Traps Tab, search for it and remove it.
biswajit.banerjee
Thanks for Support .
Issue Resolved
Thanks for reporting back. I'll close and lock the post.
