IBMIi Wizard error
GolferDad
IBMIi Wizard error
Post by GolferDad »
Doing a proof of concept...Created two host environments using the IBMi wizard. After trying to use the custom SQL wizard, all subsequent configuration changes to the host environments error out - see below
Re: IBMIi Wizard error
We do integrate IBMi wizards in Nagios XI, however they are developed/maintained/supported by IBM, not us (Nagios). I found out that you are already working with Aaron on resolving the issue, so I am going to lock this topic. Thanks!
