Nagios XI Offline Installer
dbcummings
Post by dbcummings »
I attempted to install Nagios XI 5.6.9 using the offline installer (nagiosxi-5.6.9-1.el7.x86_64.tar.gz). The installation failed saying php-mcrypt-5.4.16-7.el7.x86_64 was unavailable. I then noticed that the nagiosxi directory created when I used tar to uncompress the file was gone. It appeared to be deleted. So, I uncompressed it again, but this time I set nagiosxi as undelete-able using chattr +i. When I re-ran fullinstall, I noticed that between the installation of nagiosxi-nagiosmobile-5.6.9-1.el7.x86_64 and php-mcrypt-5.4.16-7.el7.x86_64, it attempted to remove all the files in nagiosxi. I can send the output in a PM if necessary. I think something is wrong with the installation script.
Re: Nagios XI Offline Installer
I just installed Nagios XI 5.6.9 on CentOS 7 in an offline environment and didn't have any issues.
Sure, PM me the output from the installation script.
Also, run the following commands from the command line, and show this output as well:
yum repolist -v
ls -la /tmp
ls -la /tmp/rpms
ls -la /tmp/rpms/nagiosxi
I PM-ed you, but just in case you didn't see my message, I am going to ask again for the output of the commands below:
yum repolist -v
ls -la /tmp
ls -la /tmp/rpms
